Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 09-29-2021, 03:04 AM
jimijo jimijo is offline
Default Digi 002 error inputs
Hello everyone, I'll tell you if you can help me ...
I have a Digi 002 rack connected to a MacPro 2.1 with Mavericks and Logic X, the card to reproduce the tracks has no problem but when I connect for example a guitar, after a while (it can be about 3-4 minutes) the sound, only the on the guitar, it starts to sizzle and only stops when in the Avid 003 Family application where it says "Clock Source" I change the value to any other option but it sizzles again when another 3-4 minutes pass.
The truth is that it is something strange ....... I thought it could be the cable, I have already asked for one, when I get home I try it, but in the meantime, let's see if you can tell me what it could be, I hope it is not internal fault of the inputs.
Greetings and thanks.
Old 09-29-2021, 03:08 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Digi 002 error inputs
Take a look at the firewire light. If it is blinkin or otherwise not lit continuously, you may be suffering the infamous "power harness problem" which mostly first manifests itself as a clocking problem.
Janne
Old 09-29-2021, 03:14 AM
Thanks for answering,
the lights both the front (1394) and the back (link) are on.
Old 09-29-2021, 03:15 AM
JFreak's Avatar
Good then. But do yourself a favor and google a bit about this "002 power harness issue" and if you have it you can fix it yourself if you can use a screwdriver.
Janne
Old 09-29-2021, 03:24 AM
I already cleaned the contacts but that does not seem to be the problem, it is when connecting something through the input that after a while the sound begins to sizzle, but only the sound of the input, if you have tracks they are reproduced perfectly, could it be the drivers? I use Mavericks, they told me that El Capitan is perfect, could that be it?
Old 09-29-2021, 03:28 AM
JFreak's Avatar
El Crapitan is the worst version ever, avoid at all cost.
Does this happen on all inputs or only one input? That is the key for your troubleshooting. If it is only one input, maybe that input is just bad. If it is everywhere, maybe something wrong with the clocking. And in that case simplest remedy could be buying a new FW cable.
Janne
Old 09-29-2021, 03:40 AM
It happens on all inputs,
so could it be the wire?
Old 09-29-2021, 03:43 AM
I just realized that if I leave everything without changing anything, the sound is fixed but it is heard with a lot of latency
Old 09-29-2021, 03:45 AM
JFreak's Avatar
Latency would be likely caused by your playback settings. For mixing larger buffer is nice, but I am sure you cannot record with higher settings than 256 buffer.
Janne
Old 09-29-2021, 04:06 AM
No, I mean that when I connect a guitar, for example, it sounds good, without latency, then a few minutes pass and the sizzle starts and if I leave it longer the sizzle is removed but it is heard with latency.
That is the sequence of the error.
Control 24 inputs or Digi 192 inputs?? Al Rayder ProControl, Control|24, Command|8 6 06-22-2018 05:04 PM
Digi 003 Inputs DarylBham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-21-2011 03:52 PM
having more inputs on DIGI 001 hyrobase75 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-27-2006 06:31 PM
RCA inputs to digi 002. help? grasshopper47 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-04-2005 09:21 PM
Digi 002 Inputs 5-8 starlark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-28-2004 07:15 PM
