Old 05-12-2019, 06:33 AM
bower.steven bower.steven is offline
Default Playback Engine - No Cache Size option
Hey all,
I'm trying to increase cache size, but that option doesn't seem to be showing up when I'm in the Playback Engine window. See attached screen shot.
Pro Tools 11
Macbook Pro
macOS High Sierra
Processor: 2.5GHz Intel Core i5
Memory: 16GB 1333MHz DDR3
Any thoughts as to why I don't see the Cache Size option in the Playback Engine window?
File Type: png Screen Shot 2019-05-12 at 8.21.34 AM.png (42.3 KB, 0 views)
Old 05-12-2019, 09:09 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Playback Engine - No Cache Size option
Didn't come to PT Native/Standard/Vanilla/Non-HD...whatever you want to call it until a version of 12. Unless you have PT HD 11, you are never going to see Disk Cache in 11. If you're getting an error about increasing your BUFFER size, then that has always been available.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 05-12-2019, 01:29 PM
Also keep in mind he's trying to run PT11 on a non-supported OSX.
That being said I'm running PT11.3.2 on OSX 10.12.6 (Sierra) and the only problem I've run into is the well-known issue of not being able to import audio via the drop down menu but you can import audio via drag and drop from Finder. There may be other issues with running PT11 in OSX's higher than 10.10.5 but I don't know what those are. It could be if he does indeed have PT11 HD that he's run into a compatibility issue.
Jack
QAPLA!
Old 05-12-2019, 01:45 PM
To add to what The Weed said: Disk Cache was added to Pro Tools standard 12.2, prior to that it was a HD only feature introduced in Pro tools 10 HD.
Disk Playback Cache Size? dg27 Pro Tools 12 18 06-07-2019 08:15 AM
2018.7 vs. Your Disk cache size for Playback? ihate100bees Windows 7 01-02-2019 06:39 PM
RAM CACHE not showing up in playback engine Jesslisten Pro Tools 10 7 02-26-2015 12:39 PM
Playback Engine -- Where's my Disk Playback option? Wheeltard macOS 5 03-16-2012 06:19 AM
Playback Engine Buffer Size Quinn9 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-26-2011 04:59 PM
