Old 08-01-2016, 08:41 AM
avillarreal avillarreal is offline
Default Shortcuts on Windows are not working
Hi! First time poster here but experienced Pro Tools (Mac) user.
Recently I started using Pro Tools on Windows because that's what we have at a Post-production house I currently work at. Thing is that a lot of shortcuts are not working for some reason.
For instance, the Import Video shortcut (Ctrl+Alt+Shift+I) doesn't work, and I'm 100% sure that I'm doing it right. The other one that I use a lot is "Hide All Floating Windows" (Ctrl+Alt+Start+W), and it doesn't work either.
To be clear, these shortcuts have not worked since day 1.
Thanks in advance for your help!
Old 08-01-2016, 09:34 AM
Default Re: Shortcuts on Windows are not working
Both these shortcuts work fine here. Defective keyboard?
Old 08-01-2016, 09:38 AM
The Weed's Avatar
The Weed The Weed is offline
Does Commands Focus Mode need to be on?
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 08-01-2016, 10:21 AM
It's on. So the problem it's not there.
Other shortcuts and key-commands like zoom in and out work fine. It's just a handful that don't work.
Old 08-03-2016, 06:57 AM
Found out what the problem was. It was the Language setting.
In order for your shortcuts to properly work you have to set the language to "US". Any other option won't work.
Control Panel > Region and Language > Keyboards and Languages > Change Keyboards > General > (and then add the option "US" under "English (United States")
Old 08-03-2016, 07:58 AM
PhilG PhilG is offline
That's bonkers. Was going to say test the keyboard.
http://www.keyboardtester.com/ a good site to have all the same....
Old 03-18-2017, 12:05 PM
brmusicandmore brmusicandmore is offline
I know this has been solved but I thought I would ad my similar situation and solution to this thread.
My system is windows 10. I HAD a ctrl+= shortcut problem only (switch from edit to mix window). ALL other S-cuts worked. MY problem was a program that I like to use called Tiny Spell. A spell check program that helps me with programs that don't have Spellchk. I turned it off and my shortcut problem was gone.
Sometimes small non system utilities in the system tray (the little icons near the clock in windows) can cause conflict. Tiny Spell was ALWAYS watching keystrokes (looking for spelling errors) and this was NOT good for PT. Also, because many of these utilities are watching for shortcuts to bring them up front or to activate they get in the way. So, when running PT, you should turn any and all other programs off that activate with a key-combo. With a proper PT install on a system where you ONLY use it for PT this should NOT be a issue. However, most of us use our PC for other things besides recording with Pro Tools. So stuff can happen.
I like Tiny Spell. The program is great. It just does NOT play well with Pro Tools. I am NOT affiliated with Tiny Spell. I mention it by name because it is popular and could be causing the same issue for other users of PT. And, for that matter, ANY other non system tray utility could cause conflicts. The system tray is a good place to check for issues of this kind and really, any issue that causes PT to cough and sputter. Shut down NON ESSENTIAL, NON SYSTEM utilities. :)
Have fun with PT all.
Old 04-18-2020, 08:34 PM
DFT DFT is offline
Resurrecting this, as I'm having specific keyboard shortcut issues on Win 10.
The toggle 'Tab To Transient' shortcut Tab+Win+Alt brings up tiles of all open windows instead of doing its Pro Tools job.
That is a minor inconvenience, but this one I really miss. With Tab To Transient selected, Tab + Shift works as expected, selecting consecutive regions of transients within a clip. But, Tab + Shift + Alt, the shortcut to move backwards or right to left to deselect the last transient region selected, brings the same Windows 10 tile view of all open windows.
I would love if someone could verify this ... or better still help me fix it!
Thank you.
PT10 Win7 x64 Dell 690P Dual Dualcore Xeon 3.0Ghz 16Gb Ram, UAD2 Quad (2), Steinberg MIDEX8 (2), RME HDSPe and A&H ZED R16 FW.
Old 11-05-2021, 01:47 PM
AndyVSX AndyVSX is offline
That was helpful. Solved the problem by changing the language setting. Thanks!
Old 12-12-2021, 12:32 PM
Thank you.
Your shortcut is incorrect. Its Ctrl+Alt+Tab(that's what works here and what's in the shortcuts list). If you go to the Help Menu and select Pro Tools shortcuts, type the function in the search and you can find any shortcut(if one exists)
Keyboard shortcuts (like switching mix/edit windows) stop working RiF Tips & Tricks 8 05-23-2017 02:05 PM
shortcuts that are not working... cmbourget Getting Started 2 12-22-2015 11:10 AM
Shortcuts not working mdb Windows 1 03-28-2013 11:50 AM
Shortcuts not Working??? outtareach 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-23-2008 10:34 PM
Shortcuts not working cc1 Tips & Tricks 3 09-23-2004 09:36 PM
