Old 11-30-2015, 10:13 AM
lapistola lapistola is offline
Default Blank Pro tools session Icon in finder Mac
Long story short last week I had to re-instal my PT 11 on my system and all went well. I did however notice right away that all my session icons in folders were blank. They still open fine but they are blank in folder. meaning they don’t say pro tools any more. still have the .ptx on naming scheme. I did find that older PT 9 session displayed correctly. Has this happen to anyone? Can anyone help? Thanks
Best
Luis Galdames
Old 11-30-2015, 11:19 AM
bashville bashville is offline
Default Re: Blank Pro tools session Icon in finder Mac
try repairing disc permissions
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur
Old 12-01-2015, 04:55 AM
Best
Luis Galdames
Which version of OSX and PT11? No problems here in either OSX 10.8.5 or OSX 10.9.5 with PT11.3.1.
Jack
QAPLA!
Old 12-01-2015, 06:06 PM
Post Re: Blank Pro tools session Icon in finder Mac
This sounds like a problem with the LaunchServices database.
Rebuild LaunchServices. Proceed at your own risk. I am not responsible if bad things happen to your system should you proceed as described in that article.
Old 12-01-2015, 09:29 PM
Ben Jenssen's Avatar
I agree, this sounds like it has to do with Launchservices, but this is what I would do:
Right-click on a PT file.
"Get info".
"Open with", set to Pro Tools.
"Cange all" (or similar. Translated from norwegian system.)
If it's greyed out you'll have to click the little safety-lock and enter a administrator password.
Anyway, on mac this is the standard procedure for setting what application opens which kind of file types, and it should fix the icons.
Old 12-03-2015, 06:44 AM
That article only deals with multiple entries in the 'open with' menu and not blank program icons. It has to be something systemic with OSX though as this same thing happens with Digital Performer. The odd thing though is one remedy is to reinstall DP and one gets the DP program icon back on session files.
Jack
QAPLA!
Old 12-03-2015, 11:12 AM
Perhaps the resource fork of these files is corrupted. That is the only other method I am aware of that the OS would use to match an icon to a file type. The primary way this has been done since Mac OS X v10.6 Snow Leopard was with file extensions (.ptx, for example).
Old 09-09-2016, 01:45 PM
soundgott soundgott is offline
I actually have the same problem running PT 12.5.2 on Yosemite.
Unfortunately not sure anymore when it happened.
The Get Info Window shows the icon correctly, I can even copy it and paste to another file's or folder's icon.
Just not to the ptx file itself.
I have a feeling it has something to do with Preview. The "Preview" tab in the Get Info window in Yosemite normally shows the file icon if there's nor other info available (like for example the content of a pdf).
Also with the "global" Get Info window (alt-cmd-i) I can switch between files quickly and get info for each file selected instantly. When quickly jumping between a ptx file and any other file, the ptx icon shows up for a very short time when jumping back to it in the Preview tab but then disappears.
Very weird...
Pete
Mac Pro Mid 2010
PT 12.5.2
Yosemite 10.10.5
Old 10-06-2016, 06:30 AM
jonnyx1 jonnyx1 is offline
I had the same issue of the missing PT icon with a brand new system. I was able to fix it by doing a safe boot. I saw Chef's disclaimer (Hi Chief, we know each other)! and didn't want to try his remedy unless utterly necessary.
To load your Mac in Safe Mode, press and hold the Shift key while it boots. You can stop holding the Shift key when you see an Apple logo and progress bar. To leave Safe Mode, just reboot your Mac without holding the Shift key.
Old 10-07-2016, 08:08 AM
Talking Re: Blank Pro tools session Icon in finder Mac
Hi Jonny! Glad you were able to resolve the issue with a less invasive method. I hope you are well!
Pro Tools SE blank session needed madelinenorth Pro Tools SE and Essential (Mac) 3 03-01-2013 09:57 AM
Structure patches icon from airuserblog are now Blank. oulablank Virtual Instruments 3 07-05-2010 03:42 PM
NEED HELP creating blank session in pro tools 8 le musicislife 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-04-2009 02:25 PM
Structure patch file icon blank Gothboy Virtual Instruments 2 06-28-2009 09:01 AM
session file icon blank issue ? tantejo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-05-2006 06:10 AM
