Pro Tools 11 vs Pro Tools 11 HD w/ HDX or Native Headroom difference
I read in an old SOS article:
"Because Pro Tools LE systems use the computer host CPUs to undertake all the audio processing, the LE mixer employs 32‑bit floating‑point arithmetic. Without getting into all the maths behind this, it means that there is loads of internal headroom in the LE mixer. The HD mixer is a different ball game, as it has to use the TDM chips on the Pro Tools cards, and these chips don't support floating‑point arithmetic. So, to be safe, the Pro Tools designers use a 48‑bit mixer to provide the appropriate headroom." So back in the day there was a difference in headroom between Pro Tools and Pro Tools HD due to the mixer being handled on a PCIe card. Today there is still a difference in processing--Pro Tools is handled on the CPU whereas Pro Tools HD w/ HDX and Pro Tools HD w/ Native are handled on their respective cards. Is there still a difference in headroom between regular and HD Pro Tools, assuming only one PCIe card is used? Thanks! |
Re: Pro Tools 11 vs Pro Tools 11 HD w/ HDX or Native Headroom difference
Ok cool. Thanks a lot for the response. So just to make sure I understand completely, using non-HD Pro Tools on my machine without any PCIe card, I will have "over 1,000 dB of additional headroom", same as HDX? (source for HDX headroom: http://avid.force.com/pkb/articles/en_US/faq/en423351) |
yes but you still need to output through the fixed DAC of your interface and it's limited headroom
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Can you elaborate? I'm not sure what you mean, sorry. |
It means you are still limited by whatever digital to analog converters are in the hardware you have and the analog electronics they go to. It's analogous to having a pipe carrying water and you increase the diameter of the pipe. Sure the pipe will be carrying more water but if everything downstream isn't upsized you still won't get more water at the end of the pipe.
So, does everything inside ProTools 11 and 12 software (including plug-ins) run at either 32 or 64 bit floating point regardless or the bit depth specified for the session?
Great! - that makes a lot of sense. But, how do you know that? It seems like a rather important feature that Avid seemingly does not publicize. Also, do you have or know of a block diagram for ProTools? Please excuse me if these seem like stupid questions - ProTools is relatively new to me! Thanks!!
Darryl,
So, should the 11 and 12 Reference Guides be updated to reflect that, or am I somehow misinterpreting what they say? (See attached pages from the 11 Guide.) Amack Quote: Originally Posted by Amack View Post So, does everything inside ProTools 11 and 12 software (including plug-ins) run at either 32 or 64 bit floating point regardless or the bit depth specified for the session? Yes. __________________ Darryl |
operational bit depth of the software mixer and plug-ins is independent of the bit depth of the files it works with. The pages you just shared are talking about the format for the audio files.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
So, is my impression/experience that audio files are saved (when a session is saved) at 32 bit floating point regardless of the session's bit depth selection not correct?
whats the difference between regular pro tools and pro tools 9 academic? | Abel0470 | Pro Tools 9 | 5 | 01-20-2011 01:09 PM |
The real difference between the new pro tools 9/HD native vs pro tools 7,8,9 HD!!! | endyo | Pro Tools 9 | 1 | 11-05-2010 09:21 PM |
Pro Tools LE vs. Pro Tools M-Audio - Any difference? Windows 7 | gbross | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-21-2009 08:24 PM |
Calibrate Pro Tools to give more headroom for Mic Preamp? | Vanderlae | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 12-27-2007 03:24 PM |
virtualizer clipping, pro tools headroom ok? | neonknight | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-26-2004 02:03 PM |
