Old 05-21-2014, 03:43 PM
AanoNin AanoNin is offline
Default Connecting MIDI controller properly to PT 11
Hello, I have just purchased PT 11 and no matter how I seem to situate my I/O my external MIDI Q61 Alesis is not working, even though it is recognized in the PT midi studio box. I am running the Q61 (midi out) into the MBox (midi In) and I have the Q61 USB plugged into the iMac for power supply. The screen shot below shows my config with a VST plug-in.... the VST (here the FM8) keyboard works fine on screen playing with my mouse... but how do I get it to route to the Q61 external controller? Confused.
Old 05-21-2014, 05:22 PM
xps4000 xps4000 is offline
Default Re: Connecting MIDI controller properly to PT 11
try using the audio midi app in launchpad.
Old 05-22-2014, 06:52 AM
First off - vst's do not work in PT. Only aax64 plugins.
Second - why are you using an aggregate device? Use the Mbox only.
Thirdly - do you have MIDI thru selected? And in MIDI setup accessed from Preferences do you have 'use first selected MIDI device' selected?
Jack
QAPLA!
Old 05-22-2014, 10:52 AM
mesaone mesaone is offline
You don't need the MIDI cable going from your Q61 to the Mbox. The USB connection will carry MIDI.
That might be why you're not getting any activity - the way you have it set up now, you would have to select the Mbox in the track's MIDI input selector.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 05-22-2014, 01:20 PM
ChuckS ChuckS is online now
Don't know about the Q61 specifically, but sometimes USB devices show up as a MIDI interface rather than a MIDI device (or something like that, mostly with older stuff). Disconnect the MIDI cables and try creating a MIDI device in AMS (call it something like Q61Keys) and connect it to the MIDI in/out on the Q61 shown in AMS.
If you want to keep it connected to the MBox then keep the MIDI cables connected, disconnect the USB cable, create the same Q61Keys device and attach it the MIDI in/out of the MBox in AMS.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 05-22-2014, 01:45 PM
He could leave the USB cable hooked up for power for the keyboard but that depends on the keyboard itself. Some keyboards that have both traditional 5 pin round MIDI connectors and USB MIDI can run on one or the other but not both at the same time; that selection is usually made in the keyboard itself. I'd still delete one or the other path and power the Q61 off a wall wart - Alesis does sell one - in either case.
Parallel MIDI paths like this are dangerous.
Jack
QAPLA!
Old 05-22-2014, 02:13 PM
Yeah, but my take on it is if you have a USB cable for power, why not use it for both power and data?
Old 05-22-2014, 02:52 PM
sw rec sw rec is offline
I'm thinking for no more current than is available on a typical USB port, use the wall wart wart (if it's available.)
Old 05-22-2014, 04:50 PM
True.
Jack
QAPLA!
Old 05-24-2014, 12:06 PM
Hey, thanks for all the replies! I have some maneuvering to try. I am a complete PT newbie here and learning. The VST plugins I am using are the NI Komplete 9 instruments, which do work inside PT 11... :) I will reply with my worked out solution as soon as I figure this out! Thanks everyone! :)
Connecting MIDI controller... TheHunter1787 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-28-2010 01:38 AM
connecting MIDI keyboard controller in PT PatrickJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-18-2004 01:38 PM
Need help connecting midi controller, keyboard, and rack. ixnys MIDI 1 03-04-2002 02:48 AM
Need help connecting a midi controller, keyboard, and rack. ixnys Pro Tools TDM Systems (Mac) 0 03-03-2002 04:56 PM
Need help connecting keyboard,rack, and midi controller ixnys 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-03-2002 03:23 PM
