Old 07-13-2013, 03:47 PM
Tim R. Tim R. is offline
Default Ableton Live in PT11
I was told by Ableton that the 64-bit version of Live would work with PT11. I installed the Live 8.4.1 (64bit) over my 32 bit version and Neither version of Protools (10.3.6 or 11.0.1) showed the Live rewire plugin. I fully uninstalled then re-installed the 32 bit version. Made sure it worked with PT 10.3.6, then renamed it "_32", installed the 64 bit version of Live and STILL no Live in PT11. After each install I launched Live to install appropriate elements (supposedly) before launching Protools.
Anyone have this working with PT11?
Old 07-13-2013, 04:50 PM
budda963 budda963 is offline
Default Re: Ableton Live in PT11
you have to open ableton before pro tools
Old 07-13-2013, 08:42 PM
As stated in the last line of my post.
Old 07-15-2013, 06:57 PM
Anyone (else) have this working and have insight here?
Old 07-15-2013, 11:44 PM
alexmac010 alexmac010 is offline
Last time I checked this was a recognised fault with Live 9, in the 64bit version rewire ain't working.
Old 08-06-2013, 06:30 PM
Heard from Ableton support on this (about a month ago) and they said they need to test on a system withe PT's 11 (go figure!). Haven't heard back. So anyone HERE have Ableton (8 OR 9) working with PT11?
Tim Reisig
Main System: Pro Tools Ultimate 23.12, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 22.20, Apogee Rosetta 800 w/XHD card, Avid 96 I/O
Mac OS 13.2.1, 2018 Mac Mini 3Ghz i5, 32Gig RAM
System 2: Pro Tools 23.9 (no Hardware), Mac OS 13.2.1, MBP (Macbook Air M2, 2022 24Gig Ram)
Old 08-07-2013, 01:27 AM
profdraper profdraper is offline
Works fine, Ableton Live suite 9 64bit running with PT 11. In short, delete the PT prefs & run up again.
A known issue, see this: http://www.pro-tools-expert.com/home...ewire-bug.html
Old 08-07-2013, 09:15 PM
Thanks for replies. Deleting "installedAAXPlugins" pref fixed it.
Tim Reisig
Old 09-07-2013, 12:37 AM
MGohil MGohil is offline
I had the exact same trouble, and that also fixed it for me! Thanks for the tip. I just deleted "InstalledAAXPlugins", and then restarted ProTools 11, then Ableton Live 9, and the ReWire connected perfectly.
Old 09-12-2013, 11:03 AM
AlexHill92 AlexHill92 is offline
Ditto here. I had a different problem where I would get AAE Error 20010 but deleting the file also fixed this.
PT11 AAE Error -20010 Ableton 9 (x64) Rewire? defyurself macOS 10 09-15-2016 03:11 PM
playing live, ableton live best option? shabbar3 Pro Tools 9 0 07-11-2013 05:22 PM
Tell Me Everything You Know About Ableton Live. . . epu General Discussion 5 11-10-2009 11:08 PM
Has anyone used a 192 with Ableton Live? megahurt Pro Tools TDM Systems (Mac) 2 10-14-2009 04:18 PM
Ableton Live - performing/recording live w/HD3 Surth Pro Tools TDM Systems (Mac) 1 09-11-2006 04:50 AM
