  #41
Old 08-09-2013, 06:23 AM
Spirithunter Spirithunter is offline
Default Re: pt11 hanging
Disable floppy and ProTools 11 working good! Great find!
  #42
Old 08-09-2013, 09:26 AM
We'll ProTools is kinda of working since disabling floppy. No hanging but now it has crashed on me 4x's with no error report either.ugh
  #43
Old 01-09-2014, 11:56 PM
GeneOuse GeneOuse is offline
I just bought and installed PT 11.1.1 and finally found this discussion to get a little closer to issues I'm having. None of suggestions here work for me because digiSPTIservice64.exe isn't starting properly. It does show up in task manager but it clearly fails to run properly. Windows reports that service is starting and after a few minutes give me an Error 1053 "The service did not respond to the start or control request in a timely fashion". See attached screens for more info. I desperately need help to be able to start using PT 11, at this point it is impossible to work with it, need to fall back to 10 . Spent a few evenings already and went through all tweaks suggested here.
  #44
Old 01-10-2014, 12:28 AM
I don't get what you are saying. This sounds like a well known problem that is solved by disabling the floppy drive (even if you don't really have one) in the BIOS and/or Windows device manager. Which has solved problems caused by that for every other user I am aware of who ran into this. So what are you saying? Doing both of those things did not work for you?
  #45
Old 01-10-2014, 02:37 PM
I did all the tweaks suggested here. Just to be sure I will go again through all possible BIOS or UEFI settings in my case (X79 Dark mobo) to make sure I didn't miss anything. Will report my experience.
PT11 to PT11 HD Native upgrade without hardware? kirkbross Pro Tools 11 2 11-04-2013 03:10 PM
7.3 "hanging up" Anyone else? ronwasserman Pro Tools TDM Systems (Mac) 4 12-18-2006 07:06 AM
Digidelivery hanging on 100% Medialaundry Aspera DigiDelivery 3 10-11-2005 01:27 PM
PTLE Hanging Up with XP afd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-03-2005 01:19 AM
PT hanging up while allocating storymaster2k Pro Tools TDM Systems (Mac) 1 01-10-2005 12:42 PM
