#21
Re: pt11 hanging
So starting is running. Except in my case it timed out. FWIW I enlisted a genuine Linux Command Line Bigot to look over my shoulder the second time I tried this. So I'm sure it was getting entered correctly. My issue is about PT turning white and not responding then recovering and working normally for a time. Temporary lockups. I have done all the required Windows optimizations I have seen this in both 11 and 11.0.1. I have not been seeing it in 10.x
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
#22
Re: pt11 hanging
Hi, I don't have the process digiSPTIService64.exe when I start PT11. Neither did the process digiSPTIService.exe start when launching PT10. Even after taking the steps described earlier in this thread. I tried doing a complete uninstall of both PT10 and 11 and I have now re installed PT11. That didn't make the process start when launching PT. I can start it manually though, by right-clicking on it in the service list. I´m always talking about PT 11.0.1 and PT 10.3.6, just to be clear about that. But even though this process isn't started, I can't say that I have any problems with PT hanging and freezing. I just thought that these processes are necessary for PT to run good. But since my system seems to be running fine without them maybe they aren't really necessary? So before I do more testing of uninstalling/reinstalling, I´d like to know if this process really is necessary to run? What kind of problem can I run into if it don't? Regards Markus
Windows 10 Intel core i7 4790k, 16Gb ram MacBook Pro Retina 13" late 2013 OSX 10.12 Intel Core i5 2,4 GHz 8GB Pro Tools 2018.4 Eleven Rack + Expansion pack RME Fireface UCX Last edited by surstromming; 08-07-2013 at 08:45 AM. Reason: Spelling |
#23
Re: pt11 hanging
#24
Re: pt11 hanging
Maybe I just used the wrong word as I wanted to tell that I don't see it running under the processes tab as David Sumich was writing "When PT launches, you should see this service started in the Processes tab of the Task Manager" And its not running in my processes tab. And its not "starting" in the services tab either, as he states that they should be. Therefore I want to know what potential problems I may be running into and at the same time give more info to Avid so that they can solve the problems others are having with this.
Windows 10 Intel core i7 4790k, 16Gb ram MacBook Pro Retina 13" late 2013 OSX 10.12 Intel Core i5 2,4 GHz 8GB Pro Tools 2018.4 Eleven Rack + Expansion pack RME Fireface UCX |
#25
Re: pt11 hanging
Right you are, all good points, my bad. You do have an optical drive in the PC? (I don't have any idea how this reacts if there is no optical drive?).
#26
Re: pt11 hanging
Yes, I have an optical drive.
#27
Re: pt11 hanging
This service is necessary for CD ripping on Windows. With PT 10.3.6, if the service is not running for some reason, the only side effect you will notice is no ability to rip CDs. With PT 11 however, due to the entirely new Database code, if this service is not running, you end up with these annoyingly long periodic pauses that make it impossible to really do anything. We will investigate and fix these pauses, but when things are working as they are supposed to be, you'd never see them. In other words, they are a symptom of some other problem (namely, the service not starting).
Though I've never tried it myself, the only way I could possibly imagine a situation where this service doesn't start in a normal working system is if there is no CD/DVD ROM drive. Even then, I don't know if that would cause this service to not start. Even if it did, you'd see no issues anyway, because it is specifically an issue with trying to access physical CD/DVD ROM drives. I suppose a complete "about to pull my hair out" hack would be to just disconnect the drive. While I feel completely dirty for even having said that, it did just spark the notion in my mind that I wonder if this is a hardware compatibility issue with specific CD/DVD ROM drives. Maybe that is what we can try to explore next?
David Sumich Principal Applications Engineer Avid -------------------- We're only immortal for a limited time |
#28
Re: pt11 hanging
Thanks for the reply David! Well I have a CD/DVD drive, and those services aren´t running/starting. But my system is running fine. And for that i am happy! I will post some other info here, that might help i some way maybe. When I first started to use PT11 I had some small pauses when hitting record. Not nearly as bad as some other user I´ve seen on the video he posted. Just a second or two. And then it ran smoothly. I then noticed that my old floppy drive was making some noise every time I hit record. So I disabeled that in BIOS, and the problem went away. I really don´t need that drive so thats no problem. But your idea of disconnecting the CD/DVD drive might be worth trying for those who have problems. Best regards! Markus
#29
Re: pt11 hanging
Markus, a simple experiment for you...if you can rip red-book audio from a CD in Pro Tools (via the Import Audio dialog), then that service is in fact running. There is no two ways about it. Give that a try. You won't see it in the Processes tab if you don't have "Show process from all users" checked either. If you can't rip red-book audio, then there is something wrong with the service starting.
#30
Re: pt11 hanging
I have checked "Show process from all users" though Regards! Markus
PT11 to PT11 HD Native upgrade without hardware? | kirkbross | Pro Tools 11 | 2 | 11-04-2013 03:10 PM |
7.3 "hanging up" Anyone else? | ronwasserman | Pro Tools TDM Systems (Mac) | 4 | 12-18-2006 07:06 AM |
Digidelivery hanging on 100% | Medialaundry | Aspera DigiDelivery | 3 | 10-11-2005 01:27 PM |
PTLE Hanging Up with XP | afd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-03-2005 01:19 AM |
PT hanging up while allocating | storymaster2k | Pro Tools TDM Systems (Mac) | 1 | 01-10-2005 12:42 PM |
