Old 07-09-2012, 04:24 PM
seahorsesoundstudios seahorsesoundstudios is offline
Default Used Data Recovery Service for Hard Drive and now cannot open sessions.
I get a Pro Tools error window stating that the session was created with an older version of pro tools and can not be opened.
Im am opening them on the exact same system i created the sessions on. PT LE 7.3
I tried on my other systems, Mac osx 10.6 w/ PT 9.0.6HD and Mac Lion OS w/ PT 10HD. Same error.
I tried trashing the prefs and database folders and using another drive. I also tried a new session importing the data. Same error occurs and I cant even get to the import session data window.
Is there a PT session fixer, like the program "wav fixer" . That would be rad. Any ideas!
thanks!
Old 07-09-2012, 05:06 PM
Craig F Craig F is offline
Default Re: Used Data Recovery Service for Hard Drive and now cannot open sessions.
a) do the session file(s) have and extension?
b) if they do what is the extension?
try making a new session and use import session data importing the old session
or
try adding the correct extension for the version you are using (.pts or .ptf)
Thank you,
Craig
Old 07-09-2012, 05:20 PM
Bill Denton Bill Denton is offline
When you go back prior to the PT9 days, I am reasonably certain that Pro Tools was doing some non-standard disk reads and writes (although Avid has not confirmed this).
If this is the case, the data recovery operation may have totally hosed your disk as far as Pro Tools is concerned.
Hopefully Avid can provide you with some more hopeful news...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 07-09-2012, 06:04 PM
thanks for your replies. much appreciated.
Bill, it seems like you may be on to something. Every Pro Tools files (.ptf) on the drive (every session folder and project) does the same thing and does not open. Everything else recovered fine. Odd that its only the .ptf files that had some sort of "corruption"
Craig, thanks but i tried that already and they are .ptf files. I tried messing with the extension too just in case, but it didnt work.
Old 11-21-2012, 10:21 AM
Try this; create a new session and import session data from one that refuses to open?
Old 02-06-2023, 02:10 PM
zavid zavid is offline
the very absurd thing
about data recovery softwares is the fact that the recovered files
have not the name as when assigned
but only a numerical code
perfect way for become insame...
to check each file and rename it
Hard Drive Recovery Service? philip888 General Discussion 5 08-02-2010 09:38 PM
Can't open sessions because of "bad data in Midi Chunk list" mervinwchin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-11-2007 10:09 AM
new hard drive/windows messenger service Detuned6 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-30-2005 02:45 PM
hard disk drive recovery..... Seeee Pro Tools TDM Systems (Mac) 1 09-01-2004 01:35 PM
Drive/Data Recovery in SoCal? Slim Shady 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-28-2003 09:28 AM
