Old 02-06-2012, 02:10 PM
Default Re: Dual monitors issue
Originally Posted by sw rec View Post
You only have to set it up once, though, then as they said, close with alt-f4. My windows AlWAYS open exactly where I left them.
True, and I think its an issue with Windows and not Pro Tools(but I could be mistaken).
Old 02-06-2012, 05:22 PM
Bill Denton Bill Denton is offline
It is the result of an Avid/Digidesign design decision, probably made before multiple monitors were in wide usage.
I would anticipate it being "fixed" in PT 11...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 02-06-2012, 06:31 PM
Benoni's Avatar
Benoni Benoni is offline
I believe you are correct. Adobe products work sort of the same way for Windows but not on Mac (having a back container window)
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 02-08-2012, 05:03 AM
ejwells's Avatar
ejwells ejwells is offline
Ummm...it's obviously a Windows issue, seeing as it's not an issue at all on a Mac.
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack |
Old 02-08-2012, 08:55 AM
Nope...
Remember that you can drag a plugin window outside of the "main" window in Windows. And if you're using IE 9, you can drag a tab out of the browser window and it will become a separate browser window.
It's simply a choice made by Avid's system designers, probably a number of years ago...
X
Bill in Pittsburgh
  #16
Old 02-08-2012, 01:45 PM
ejwells's Avatar
No, you're not mistaken at all.
It is an issue with Windows.
  #17
Old 02-18-2012, 11:07 PM
Odebode Odebode is offline
wow, so is PT the O/S, or is Windows? Gotta love the PT homers on this forum.
btw, I have dual monitors that aren't the same size, so it's very difficult to drag a window across the monitors and have it display in such a way that works for me.
  #18
Old 02-21-2012, 08:53 AM
Larry Sheehan Larry Sheehan is offline
Yes, it's a PT design choice. In Reason, I can undock the mixer and move it outside the parent window. If it's possible in Reason, it should be possible in PT.
Vegas allows the same thing with the preview window being undockable too.
Larry Sheehan - San Gabriel Sound
  #19
Old 02-21-2012, 02:26 PM
deanrichard deanrichard is offline
No, it is definitely not a Windows issue. It is an Avid design decision. Samplitude, for example, allows one to drag the mixer over to a second monitor with no problem whatsoever. In fact, I wish Avid would take a cue from them.
The real issue might be that the PC platform has always been Avid's second choice, and many of the "niceties" of the Mac platform are simply overlooked or not considered important. Or it could be because they use a common code base, and the windows version of their library is lacking key features. Or the final plausible explanation is that their Windows programmers simply aren't as good as the Mac programmers. Whatever the reason, they don't do it.
But it's not only possible to put the mixer window on a second monitor, it's a very cool way to work.
  #20
Old 02-21-2012, 02:33 PM
Nonsense. Samplitude does it, Reason does it, and several other apps as well. Nothing about the Windows platform forces an app to work the way PT works. It's great to work with the mixer on a separate monitor, and I hope PT allows it some day.
Dual Monitors? mix_master_adam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-27-2005 12:50 PM
5.3.1 & XP with Dual Monitors.... seanhupe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-01-2003 09:18 AM
Dual Monitors? Sabe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-24-2002 12:58 AM
Dual Monitors....please help msglider 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-17-2002 05:10 PM
Anyone using Dual monitors on the 001? Gremz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-15-2000 01:14 AM
