#41
Re: Pro Tools 10 XPAND2 No Sounds?
Hey Lads,
This problem was driving me mad...no plug-ins!!! I was desperately shifting files around and then when I put them in /Applications/Avid/Pro Tools/Plug-Ins they finally came up in the Insert menu. It seems PT10 looks for the plug-ins in that folder! Best of luck! |
#42
Petter |
#43
Now it works!
I uninstalled pro tools completely and when reinstalling the virtual instruments, I realized that THERE ARE TWO FILES COMPETING FOR ATTENTION IN THE FOLDER: "virtual instruments setup" and "virtual instruments". Both look to be doing the same thing (but perhaps do not in fact do so), so if I click on the blue digidesign-logoed "Virtual instruments setup", the software starts installing. Everything looks fine except I cannot get any sounds from Xpand. BUT there's a less official-looking "Virtual instruments" (installer) file there, too. When I installed using this latter installer only, without then clicking the virtual instruments setup icon at all afterwards, pro tools DID (when opening Xpand) prompt me to look for the "big" folder. Works. So, if you have the above-described problem, do check which file you've used for installation ... best, Petter |
#44
Hi Petter/Korkman, and the rest of the DUC.
Unfortunately, I am having the same issue with Xpand2 in PT10 (brand new and old sessions). I can open Xpand as an insert on a mono instrument track, and I can select the presets from the top dropdown menu, but then nothing happens and I have no sounds from Xpand. I have tried everything I can think of (un-install/re-install, downloading new versions of the software from avid, etc), but no luck. I also tried Petter's trick with the install. SYSTEM Win 7 64bit, i7, 12gigs ddr31600 ram, 1 system drive and 1 internal recording, and 1 internal backup drive, iLok licensed PT10 (upgrade from PT9), Digi 002r, T1 firewire SIIG card (the avid recommended card), Gigabyte ga-x58a-ud5 Motherboard, GeForce GT 440 1 gig graphics card. PT10 and everything else (plugins, etc) seems to be working fine. Any further advice and support would be greatly appreciated. I've had to cancel several days of sessions already. I'm losing hope. Thanks everyone! |
#45
AN here am I about to quit recording cos of ill health and PT with PT 10 is working sweet at long last. Its much better than 9 though I did have 9 working too. I think you will find if you install with the 10.0.1 updater that all will be well as they have fixed these kind of problems at last.
Best F |
#46
Has anyone found a solution to this problem? I'm having the same issue after moving to Pro Tools 10 from 9.
Xpand has no presets. After searching the forum I believe the problem is that Xpand needs to be pointed to the Xpand!.big file. But I can't get Xpand to pop open the dialog box asking me where it is. Is there a regsistry setting that can be set to point to the file? Last night I uninstalled Avid Virtual Instruments and reinstalled, but same thing. No presets. |
#47
#48
#49
That worked! Thanks.
#50
Awesome man! Let me know if your sound quits after a few seconds of playing. I have a session with Xpand2 and now it loads but the audio stops working out of Xpand2 after a few seconds of playing, either playback or even midi playing it just stops. I have to disable and renable just to get it play but it doesn't even play for long.
Certain XPand2 Sounds Missing | MogDog | Virtual Instruments | 1 | 04-14-2013 04:37 PM |
There are no sounds in xpand2 | SEMMO | Virtual Instruments | 21 | 04-21-2012 06:16 PM |
Are Xpand2 Sounds Available To Other Plug-Ins/Samplers? | taylor4814 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-27-2009 09:21 AM |
Favorite Xpand2 sounds. | chrisdee | Virtual Instruments | 0 | 04-20-2009 03:33 PM |
Sudden loss of sound while auditioning sounds in Xpand2 (Pro Tools 8) | chrisdee | Virtual Instruments | 21 | 04-14-2009 12:54 AM |
