PLEASE HELP Eleven rack no input signal
I have no input into the eleven rack, its not reading any signal i put into it. Is there a reset or something i can do.
It doesnt get any signal in standalone or inside protools, guitar is fine, cables fine. Nothing even through the headphones, what could it be. Im starting to get pretty freaked out about this now. Please someone help |
Re: PLEASE HELP Eleven rack no input signal
Well if you have gone through the settings and made sure you have your input and output set correctly, and volume up - and still no input, then you could try a hard reset
Hold down REV-MOD-FX LOOP while booting. This will wipe out any user created rigs also. You may have to re-install Firmware 1.0.3 after this im not sure, never actually had to do a re-set myself.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
that didnt do anything, i guess ill try to reinstall the firmware!
Thanks for your help, i guess maybe i could bring it back and try another unit. i just hate to do that! |
You may have an old stock unit. Is the clock set to 44.1? If so, try 48 and see if you get sound, if so, call avid for a swap.
Schecter C1 Elite, Schecter C1 E/A, Epiphone Les paul Custom Silverburst, Fender Mexi Strat, Ibanez RG, Damage Control Demonizer, Boss Gt10, Eleven Rack, Carvin TS100 Stereo Tube Power Amp, 2 Fender Roc Pro 1000 Cabs. Intel Core 2 Quad Q9550 @ 2.83Ghz. OCZ Platinum 4GB DDR2 SDRAM DDR2 1066 Foxconn G45M-S LGA 775 Motherboard Antec Three Hundred Case Windows 7 Home Premium Pro Tools LE 8, Cubase 5. |
How would i know if i have an old stock number i just bought it last week, the build is 0.6.2.0
are the older ones more prone to fail? |
It's a known issue. I bought mine 1/28 and it had that problem. Avid was great about replacing it for me.
Eleven Rack Only Recording Dry Guitar Signal no FX | Imran5000 | Eleven Rack | 18 | 07-20-2017 07:50 AM |
No signal from Ditto Looper in the FX Loop of the Avid Eleven Rack | dcasner64 | Eleven Rack | 8 | 02-18-2014 06:11 PM |
Eleven Rack FX Loop - True Stereo Signal Flow? | jyang | Eleven Rack | 7 | 02-18-2013 09:48 PM |
Eleven rack: mono track to record the processed guitar signal | Eric Tannery | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-06-2010 04:46 PM |
no input signal digi 002 rack | twomba | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-03-2007 07:53 AM |
