Old 05-05-2010, 07:52 AM
schristie schristie is offline
Default Eleven Rack - Standalone - No sound on startup
Hey all - new to the forum and Eleven rack. I tried seaching and didnt find much on the problem I'm having with my new 11R.
When I run in stand alone mode with input set to guitar, output to full rig and nothing muted that I can find I'm having an issue.
When I turn on the unit, it goes through a start up routine and most of the time I get nothing...no signal recognized at the input...no sound, no tuner function...
If I turn the 11R off and on several times, eventually it works fine.
I've tried several cables to make sure that it wasn't an issue with a cable.
It is brand new fresh out of the box and it appears that it came pre-loaded with latest firmware.
Any suggestions?
Old 05-05-2010, 10:59 AM
bender-offender bender-offender is offline
Default Re: Eleven Rack - Standalone - No sound on startup
If you feel you've minimized the problem to the Eleven Rack I suggest calling tech support. I had some problems with my ER when first purchased and tech support helped me out big time. I think they do an awesome job.
Mac Pro 8-core 3ghz, OS 10.6.7, 16GB ram PT 8, Digi002, Cubase 6, Logic 9, MOTU 2408mk3, Eleven Rack
Old 05-05-2010, 11:59 AM
Man, I was really hoping someone had "magic" button that I could push to fix my problem.
At the end of the day, this doesnt give me a sense of secuirty with the unit so an exchange seems the best route since I haven't registered the product or opened the software yet.
Thanks for the reply,
Steve
Old 05-05-2010, 01:25 PM
bluegate bluegate is offline
Try a memory reset.
Go to the User Settings and reset the memory.
Old 05-06-2010, 05:24 AM
Thanks for the tip...memory reset seemed to do the trick.
Old 05-06-2010, 09:01 AM
Great, now you can enjoy it like we do
Old 05-08-2010, 05:39 AM
fotat fotat is offline
I have the same problem !!!
and sometimes, the time to be running +/- 5 minutes, turns off the sound, no sound on ouputs !!! a drama if you're playing live
Solutions are closing the power and start again !
I try to do a reset the memory to see if I'm lucky ...
thanks
Old 05-11-2010, 11:46 PM
starflyer425 starflyer425 is offline
I'm having the same problem. Standalone mode; takes 3-4 power on/off cycles before I get any sound. Mine came with ~100 presets from Sweetwater; if I try the memory reset, will 11R erase all the presets?
Old 05-12-2010, 05:01 AM
madgt621 madgt621 is offline
Location: Current: Ikebukuro, Tokyo, Hails from: San Francisco
i'm not sure if the Sweetwater presets will be erased, but you can just save the presets to your computer. If you reset, and the Sweetwater presets are erased, just load them back in from your computer.
Macbook Pro OSX 10.6.8, 2.53 GHz Core 2 Duo, 8 GB RAM
Pro Tools 10.0.0
Ableton Live 8.2.1
RME Fireface 800
Eleven Rack
Old 05-13-2010, 12:29 PM
yes, all user preset are return to factory initial.
be sure you have a copy of your presets in your hard disk
Eleven Rack Standalone Editor brianiac5150 Eleven Rack 315 02-07-2015 04:53 PM
Eleven Rack not Booting in Standalone Mode mjmurray Eleven Rack 2 07-16-2012 10:29 PM
Eleven Rack Standalone driver, and editor. Blurgh Eleven Rack 22 01-09-2012 09:16 AM
Eleven Rack- No sound on Startup- Help Needed MJFrench Eleven Rack 13 01-02-2012 03:27 PM
002 RACK AS A STANDALONE SOUND CARD BASHBROS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-03-2007 12:44 PM
