Tech Problem -> Output of PT Audio switching L & R before interface. Need help!
Hey,
So tonight I just noticed that the outputs of my master bus in PT are getting switched before they reach the D/A. I hard panned a GIT Left and I heard it out of the right speaker. My first reaction was to check speaker cables, but it is definitely happening BEFORE it reaches the D/A as the meters read opposite. Pro Tools program is working fine in the mix window, as when I hard pan left the master meter reads left, but the interface reads right. I checked the I/O screen and the matrix is set up correctly, with the Analog 1 being assigned mono left and the Analog 2 mono right. As a quick fix I swapped the left and right in the matrix... but I don't like that solution. It shouldn't be like that. I reseated the interlink cables, reset all units and computer, but no change. I deleted all paths and imported my previously working matrix but no change. If anyone has any input, I would be greatly appreciative. My quick fix is working but I don't like the idea that I should have to change that for every session and not have signal flow consistency. Please help!!! PT HD2 Accel PCIe 8.0.1. Apogee Rosetta 200 as D/A. All other signal flow is correct. |
Re: Tech Problem -> Output of PT Audio switching L & R before interface. Need help!
What happens if you run another app with coreaudio driver? itunes for example. TRash all prefs? Reset the hardware setup and the i/o setup? Chris
No Interface need Audio Output through Internal Speakers | wackjaw | Getting Started | 7 | 03-04-2014 03:24 AM |
problem with sound output to interface/external speakers | jessiful | macOS | 8 | 04-24-2013 01:34 PM |
Eleven Rack: Headphone Output Impedance & Amp Output Tech Specs | MR290378 | Eleven Rack | 12 | 11-29-2011 05:10 PM |
192 Interface Output Problem | roughmixer | Pro Tools TDM Systems (Mac) | 1 | 06-01-2009 09:04 AM |
No audio output from my midi interface - please help | gab123 | Pro Tools M-Powered (Mac) | 1 | 11-08-2007 03:39 PM |
