Bounce to Quicktime with 5.1 audio?
Is it possible to bounce a 5.1 mix to Quicktime (along with video) using ProTools?
Thanks in advance, pb |
Re: Bounce to Quicktime with 5.1 audio?
Quicktime 7 does support 5.1, but I have not found a way to bounce 5.1 directly from ProTools with the video. It's a bit of a pain, but you can export the quicktime movie without audio, then export as the 5.1 stems as Quicktime, then open each audio file in quicktime, select all under edit, copy, then open the video and select all and add to movie, then under audio properties, select the output L,C,R,LS,RS,LFE and repeat for the other 5 tracks.
Rick Sanchez http://www.posthastemedia.com MacPro 2x2.66 GHz Dual Core "WoodCrest" Mac OSX 10.5.8 / 4 Gig Ram ProTools 8.0.4 Digidesign/Magma PE6NE-I upgraded 6 slot expansion chassis. (Host card in Slot 2 of MacPro) HD3 Accel BlackMagic Decklink Studio 2 (In Slot 3 of MacPro) SurCode / Dolby Media Meter 2 Izotope RX2 Advanced / Sonic NoNoise Waves Platinum 7.x / Serato PitchnTime Melodyne Studio / Altiverb XL / Speakerphone KOMPLETE 7 EQuality / Massey L2007 TC MasterX |
Can you not save a step there by exporting a 5.1 WAV from PT and adding it to the movie in one go?
Bounce Surr Audio 5.1 to a Quicktime Movie in PT | gives | Post - Surround - Video | 7 | 03-02-2007 02:57 PM |
Quicktime bounce results in mono audio | davidark | Pro Tools TDM Systems (Mac) | 5 | 09-29-2006 04:59 PM |
Bounce To Quicktime Only Outputs Audio | Willard | Pro Tools TDM Systems (Mac) | 17 | 08-29-2005 06:27 PM |
Bounce to Quicktime Movie Creates Only AUDIO ?! | DMK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-11-2005 02:56 AM |
Bounce To Quicktime Movie creates only AUDIO | DMK | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-21-2005 05:33 PM |
