Bounce to disk problems
I have Os 10.3, G5 1.8 single, 1.5 GB Ram using PT LE 6.9 and a Digi 002... I'm attempting to bounce a song with some effects (amplitube on two tracks, only 4 tracks of audio, 88.2 sample rate convert to 44) I have a Lacie D2 120GB and I keep getting the error message:
DAE can't get audio from the drive fast enough, Your drive may be too slow or fragmented, or a firewire drive could be having trouble due to the extra firewire bandwith or CPU load (-9073) I've done test bounces using other pieces of music w/out the DAE and it worked, sometimes it won't even let me play back fully. Is my system too slow to handle 88.2 with multipile DAE? Song is about 6 minutes Should I defragment the drive? I'm mixing it down to the same Lacie external that the source material is recorded on... Should I bounce each track w/ DAE individually and then import? Any solutions/ideas? thanks in advance... Sorry for the long post.
G5 1.8Ghz Single OSX 10.4.8 PT LE 7.3.1 DIGI 002 ATA Drives |
Re: Bounce to disk problems
Make sure you have selected the beginning and end of the session you want to bounce. You may not have set a limit for the end of the song and are trying to bounce a lot of empty space at the end.
From the Pro Tools LE 6.9 Read Me for Mac: DAE Error –9073 when Recording to a FireWire Drive and the 2 GB File Limit is Reached (Item #42611) When the 2 GB file limit is reached during recording to FireWire drives, a 9073 error is posted instead of the expected “Recording has been terminated because a disk is full” dialog. This error is benign, and does not signal any data loss or problem with the hard drive. There are a number of results for a search on 9073 errors. If you haven't, go to the Support section: www.digidesign.com/support and in the Support Search on the left side, enter just the error number: 9073 which should give you all of the Answerbase results.
Administrator Avid Pro Audio Community |
Bounce to disk problems ! | ley | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 04-21-2008 09:50 AM |
Bounce to disk problems | Punkbarn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-19-2007 11:53 PM |
Bounce to disk problems | pinkdaygreenfloyd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 01-07-2006 08:42 AM |
bounce to disk problems! | SwedenPar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-14-2005 07:41 AM |
Bounce to Disk Problems | sambora68 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-30-2004 11:40 AM |
