Old 04-08-2005, 05:08 PM
jkilbride jkilbride is offline
Default Please help - Digi002 blank screen
I've had my Digi002 for a couple of years, but have never used it that heavily. I'd noticed that every once in a while the screen would go blank and it would lose it's connection with Pro Tools. To fix it, I would have to switch it off and then back on again. Well, now it's happening all the time! I switch it on, it goes through the "Validating..." step then says "Ready". It works for a few minutes and then the screen goes blank. Sometimes resetting it will fix it for a few more minutes, other times the screen will come up blank even after resetting -- or even stranger, a weird pattern of dots appears across the screen. Has anyone ever seen this before or know what's happening?
I think it's a problem with the unit itself. I have the 002 setup as my main output source in my Sound control panel, so I can play iTunes, etc... through my studio speakers. This freezing problem happens both when I'm running Pro Tools and even when I'm just using the 002 for sound output. I have a PowerMac G5 dual 2.0GHz with Pro Tools LE 6.7.
Any help is appreciated. I'm not looking forward to carting it down to a repair shop...
Thanks!
--jeff
Old 04-08-2005, 09:11 PM
Default Re: Please help - Digi002 blank screen
welcome to the DUC. your problem sound like the infamous power harness failure that is well documented on this site. You will find a lot of good reading here so try to spend some time reading anything and everything. Call DIGI's customer service and they will likely send you a new harness even though your 002 is out of warantee.
Old 04-09-2005, 08:22 AM
Alex TCH Alex TCH is offline
i have this problem regulary for a year! can you give the exact way to find out the right answer - if it is not so hard to you please!
[email protected]
Digi 003 lcd screen is blank Skeme 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-25-2013 06:14 PM
Help! Hybrid Blank Screen nicholasivan Virtual Instruments 10 11-17-2010 07:44 PM
DIGI 003 Screen is BLANK Soundwave0789 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-15-2008 03:21 AM
blank gray screen on tilt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-09-2007 03:40 PM
6.1.1 Hardware set up screen Blank wire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-17-2003 10:10 AM
