Digi 002 or Digi 002R w/command8
What are your thoughts?
What is the difference and is the command 8 a better control surface. Goods ....Bads ? Thanx frank http://www.upinthenitemusic.com
rokalias |
Re: Digi 002 or Digi 002R w/command8
I own a 002r and a C/8 and I like it alot. Right now I don't use the monitor section but I think I will hook it up to see how it performs. I like the fact that my audio interface is in the rack and my control surface is on my desk. The C/8 has a better display than the 002 too. I haven't used the 002 so I can't compare them very well.
Intel I7 920 Asus P6T Digi 002R. Command/8 PTLE 7.1 MPT www.clearspotrecording.com |
I want to know the same thing. Let's get more replies
I use the C|8 with 002-R. It's a good combo. Less space is used on my desktop. Keyboard sits underneath desk on movable keyboard tray, directly below C|8. The display is better than the 002, also.
----------------------------------------- 2.2 Ghz Intel, XP-P, 002R, c|8, Rode NTK, BX5's Primary use: Voice-over work Addiction: Music (bass) |
Another 002R/C¦8 user here. The combination is great. The only thing I miss on C¦8 is a jog wheel, for which I'd be prepared to pay another $50 or whatever towards the extra cost if implemented.
this may be an unenlightened question.. but why would you use a 002r with the C8 instead of just the 002 desktop?
Mac Mini 2.4 5GB Ram Pro Tools 9 Logic X KORG Triton Extreme |
Amd 64 300+ Asus K8VSE 1GB ram 128MB Video card Win XP GT050 160HD Pro Digi002r Command|8 & Pro Tools 6.7 w\ Waves Diamond 5.0 |
Also, the C|8 works with the M-box, too. So, for a very low entry cost to Pro Tools, the C|8 permits you to have a external harward mixer with touch sensitive faders, etc. For me, I had the M-box and later upgraded to the 002-R. It's a nice path. Now, assuming you have a multi-track session you can mix it.
Also, I see the advantage of putting the 002-R in a rack and having only the control surface on my desk. In my configuration, the 002-R sits to the right of the monitor, which is on a shelf above the desktop. The C|8 sits below the monitor -- almost centered below the monitor -- on the desktop. CC
hey folks:
i have a new command|8 running with my HD|2, having just upgraded from a happy 18 months on the 002; i think the build quality of the command|8 is slightly better than that of the 002 - the feel of encoders and buttons is a bit more solid, and certainly the display is far superior - i do wish it would boot with the control room outputs muted though, as the 002 did; here's a drawback for those of you one day considering a jump up: the 002 gives you 18 channels of i/o, and i grew quite used to having my DA78 coming in the lightpipe while also having send and return for an effects loop to my eventide eclipse on the s/pdif ports; now with the 96 i/o i only have 16 channels of i/o, and i have to deselect channels 7-8 of the DA78 when i want to send to the eclipse - sad! but cool that you actually get more i/o on the 002. enjoy! sp/L/icy |
Digi 002R as ADAT Slave to Digi 003R? | Curdie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-01-2011 01:46 PM |
Digi 002 vs Digi 002R W\Mackie Control Universal | Lance Driskell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 02-28-2006 12:41 PM |
Digi 002 or Digi 002r? | spasticchild | General Discussion | 4 | 12-01-2005 07:12 PM |
002r with command8 or MCU? | AM STUDIOS | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-24-2005 11:02 PM |
002 and 002r+command8 | norm14 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-10-2004 02:37 PM |
