Strike MIDI note question
I noticed that there is a conflict between PT MIDI notation and Strike notation:
For instance Strike uses D#2 but PT MIDI notation uses Eb2 and therefore it won't play when I write for Eb2... Any ideas?
G5 1.8Ghz Single OSX 10.4.8 PT LE 7.3.1 DIGI 002 ATA Drives |
Re: Strike MIDI note question
filosofem
Aaron Mulqueen - 001 HD Native |
Thanks, I changed the key signature and it worked. I was in C major. I was laying down patterns in the method you had suggested in one of your posts: Using PT MIDI notes to program Strike.
Another question: Is it possible to program more than one event at one time. For instance, I'd like to add a trigger cymbal crash to a Strike pattern is it possible to do that using the PT MIDI interface?
Use the 'Assignable Trigger Zone' (Blue Trigger Keys) C4-B5. To assign an Instrument right-click either of the Trigger Keys and mirror this on the Instrument Track.
filosofem
Yes, that's what I've done. And it doesn't play the crash during playback. Could there be something in the settings preventing it from playing only the pattern?
thanks again for all of your help.
Hmmm... not to my knowledge. What Crash assignment are you using and at what pitch?
filosofem
It was there, it was just too low in the mix.
Raise the Velocity Value (Track View) for the Trigger Keys.
filosofem
filosofem
MIDI note reassignment question | MBRULE | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-17-2012 06:11 PM |
STRIKE Midi note sound duplication | drasmith | Virtual Instruments | 19 | 05-14-2011 03:25 PM |
strike will not play a midi note on a track | Filmusic | Virtual Instruments | 2 | 07-30-2010 12:48 AM |
MIDI Pencil Note Question | Wheeltard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 02-27-2009 07:49 PM |
PT 5.2 midi note question | Arnold Drummand | MIDI | 1 | 01-14-2004 08:37 AM |
