Old 09-11-2007, 08:56 PM
Lugh98 Lugh98 is offline
Default error message: This volume set to \"transfer only\"
I go to open my project that I was working on fine with last night, and I get that all of the disks (internal/external) are set to transfer, the V column has all the drives set to R, but when I go to change the A column to Record it says that it isn't a valid audio volume.
Also, I installed and upgrade avid xpress pro 4.8 which is not compatible to osx 10.4.8 Could this be causing the problem?
Any ideas?
Thanks...
G5 1.8Ghz Single
OSX 10.4.8
PT LE 7.3.1
DIGI 002
ATA Drives
Old 09-11-2007, 09:57 PM
Big Daddy Koop Big Daddy Koop is offline
Default Re: error message: This volume set to \"transfer only\"
I had to use the OS software to format my external drive to get it to work....You may want to try that (It's under utilities).
The upgrade could be a problem, but don't take my word on that.....someone else can probably better answer that question for you.
Old 09-11-2007, 09:59 PM
Sorry....the utility you need is called "Disc Utility" You need to format it as Journalized.
Go to Applications, utilities, then Disc Utility.
Good luck.
Old 09-11-2007, 11:37 PM
joey santos joey santos is offline
you need to format your drive with the disk utility function, dont forget to put it as "journaled". happened to us when we updated to 10.4.10.
Hope you can get your system to work asap
ciao!
Old 09-12-2007, 05:06 AM
So I have to erase all of my drives for PT to see them as recordable again? I'm also unable to change from transfer to recordable on my internal drives as well. Maybe re-install the software?
thanks
G5 1.8Ghz Single
OSX 10.4.8
PT LE 7.3.1
DIGI 002
ATA Drives
Old 09-12-2007, 08:35 PM
ee8 ee8 is offline
I've had this happen before, and I just close PT and reopen, then it allows me to change to R.
2.5 Ghz G5/ 4 GB RAM
10.4.8
PTLE 7.3.1cs1
002 Rack
External HD transfer/record error message Che_Guitarra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-25-2007 11:17 PM
Mac Newbie and Volume Set to Transfer only error jjhuntfox Pro Tools TDM Systems (Mac) 2 02-12-2007 12:44 PM
Error Message "Not a valid audio volume".... SunriseSeagull 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-30-2005 08:41 PM
I'm Getting A "Audio Record Volume" Error Message MITCHELLBOY 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-15-2005 06:20 AM
Please HELP! Audio Record Volume error message! kseconds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-13-2003 12:47 PM
