Old 05-06-2019, 05:30 PM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: 9129 Errors All The Time
Hi friend any update on this ?
- Jesus Alvarado -
Keep the volume UP !
Old 05-07-2019, 01:54 AM
the.engineer the.engineer is offline
Originally Posted by blvdrecording View Post
Thanks for the suggestions.
Also interesting, anytime i close pro tools or reboot? My converters shoot to 192 and make noise. Its the mac doing it to the converters, not the converters themselves. I have to go reset the sample rate to get it to stop or to even open Pro Tools. Theres something else going on.
This is to do with Audio MIDI Setup. When Pro Tools is closed Audio MIDI Setup will have it's own default sample rate for the HDX card. If it's way higher (192) than your typical session, that's what causes the spikes when you close Pro Tools. To fix, open Audio MIDI Setup (with Pro Tools closed) and choose a sample rate for the HDX card that's the same or close to the same as your typical sessions.
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Pro 5,1 (Mid 2010) | 3.46GHz Six-Core Intel Xeon | 32GB Ram | AMD Radeon RX 580 8GB | Apple 27" LED Cinema | 500GB Samsung 960 EVO M.2 SSD System Drive | 1TB WDC Sample Drive | 4TB RAID 0 Seagate Audio Drive | UAD-2 Quad PCIe
Mojave 10.14.5 | Pro Tools Ultimate 2019.5 | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
Old 05-09-2019, 08:45 AM
PeterScherr PeterScherr is offline
Hi There,
I notice that you are using a UAD processor.
When I start to get a lot of 9129 errors, I uninstall my UAD software using the uninstaller, and then manually uninstall UAD prefs. That usually helps a lot.
Inside the prefs folder, there are at least two "loose" items with the Universal Audio name, and also a Universal Audio folder. Delete these, and re-install your UAD software and see if that helps.
I've made this part of my regular maintenance, say once or twice a month...
All the best,
Peter Scherr
-9129 errors??? PT user Pro Tools HDX & HD Native Systems (Mac) 0 10-11-2012 01:25 PM
-9129 errors & 10.3 PT user macOS 8 10-02-2012 03:47 PM
9129 Errors jjhuntfox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-11-2006 10:12 AM
9129 Errors passage Pro Tools TDM Systems (Win) 2 12-26-2005 07:48 PM
9129 errors and I don't know what to do Paul McEvoy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-12-2005 08:48 AM
