Old 04-07-2019, 02:47 PM
blvdrecording blvdrecording is offline
Default 9129 Errors All The Time
1 Pro Tools HDX PCIe Card
2 Lynx Aurora 16 converters
Mac Pro (Mid 2012)
2 x 2.4 GHz 6-Core Intel Xeon
32 GB of ram
OSX Yosemite 10.10.5
Pro Tools 12 12.8.0
UAD Octo PCIe
It was stable until I upgraded from the last version of 12. Now I've got all sort of errors. Even get errors when I use busses on a track for the first time. Its getting in the way of everyday sessions. Just had a prominent engineer in here for the first time and I think the errors turned him off to the studio which is a real bummer. Now I cant track unless Im at least 1024 or double that. Otherwise it stops every few minutes.
I've disabled spotlight, the wifi search option, dumped prefs, its a bummer. Wondering if upgrading will help or make things worse.
Also my core audio drivers do not work.
Old 04-07-2019, 06:32 PM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: 9129 Errors All The Time
Hi a few things to do here if you will .
You said the core drivers are not working
Go to your Mac OS drive> library> preferences > Audio . And delete the 2 plist files that are located there .
( their names are audio related )
The from the GO tab in your finder menu when the menu displays hold down the tab key to make the library folder appear if it is hidden and click it .
From there go to preferences and find inside a plist named :
com.apple.audio.AudioMIDISetup.plist
and delete it too .
Then reboot ( please read well your gonna delete important OS files ). This will reset your audio devices upon the next restart .
Optionally later you can go check that everthing is ok on audio/midi setup on your mac OS settings and delete the protools aggregate from the audio/midi setup . It will generate itself with the next PT start .
And last go to your PT IO settings and default everything there . In , Outs and busses .
Hope this helps .
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 04-07-2019, 06:34 PM
jeam25's Avatar
For the error 9129 please check that all your plugins are up to date . And test copying your session to another hard drive to see if the issue persist .
You said you did but recheck ALL the OS optimizations again .
Protools Ultimate
Old 04-08-2019, 02:05 AM
Thanks for the suggestions.
As far as the Core audio goes, i did all as requested and still nothing has changed. I have no AVID HD in my audioMIDI setup i also dont have it in my sound preferences.
Also interesting, anytime i close pro tools or reboot? My converters shoot to 192 and make noise. Its the mac doing it to the converters, not the converters themselves. I have to go reset the sample rate to get it to stop or to even open Pro Tools. Theres something else going on. Its really a bummer. I use to have paid support.
Also still getting the errors on the playback.
Old 04-08-2019, 03:52 AM
Southsidemusic's Avatar
Don’t you need a Digilink license to run HDX above PT 12.6 HD
Avid added that in 12.6.X so if you are not on a support plan which include a digilinl license maybe thats why you dont see the HDX card or core audio. What PT version did you update from?
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 04-08-2019, 07:04 AM
jeam25's Avatar
Apart from what christopher said/ask please check all you cables conections and reset/change if needed . ( especially word clock cables if any ) .
Protools Ultimate
Old 04-24-2019, 11:54 PM
Never heard of that... I upgraded some time ago from 10 but I had support for the first year and everything was fine. I sorted my issue with core audio, hopefully it will stay this way.
However I am still having horrible issues with the 9129 errors stopping in sessions with hardly any plugins. Im wondering if its at the point now that I have to wipe all of my plugins and reinstall ?
Old 04-24-2019, 11:55 PM
Definitely not a word clock issue as far as I know. This only happens on some sessions.
Old 04-25-2019, 08:01 AM
jeam25's Avatar
Hi again did you try running PT without any hardware attached ? Just with the Internal Card ?
Protools Ultimate
Old 04-25-2019, 08:48 AM
Hi again did you trt running PT without any hardware attached ? Just with the Internal Card ?
Meaning run using Built-In Audio as the playback engine... not HDX.
I'd also remove the Octo card and UAD software, you have a lot going on here and need to troubleshoot/simplify things. A single UAD plugin accidentally used at smaller IO Buffer settings can cause CPU problems.
-9129 errors??? PT user Pro Tools HDX & HD Native Systems (Mac) 0 10-11-2012 01:25 PM
-9129 errors & 10.3 PT user macOS 8 10-02-2012 03:47 PM
9129 Errors jjhuntfox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-11-2006 10:12 AM
9129 Errors passage Pro Tools TDM Systems (Win) 2 12-26-2005 07:48 PM
9129 errors and I don't know what to do Paul McEvoy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-12-2005 08:48 AM
