Old 10-24-2017, 05:50 AM
RTD RTD is offline
Default Create an 14kHz / 8bit / mono file
Hello,
A client needs an 14kHz / 8bit / mono file for a speaker system in cinema's.
Is this possible with Pro Tools 11?
I did found out you can downscale with the Lo-Fi plugin, but I do not know how to get to 14kHz and how to properly export the audio.
Thank!
Old 10-24-2017, 09:03 AM
I doubt you have the specs right here. What *exactly* is this for? What hardware is playing this back? From what media? What actual format e.g. linear PCM?
14kHz is used as an analog sync frequency, are things getting confused with that?
Old 10-25-2017, 12:34 AM
RTD RTD is offline
Default Re: Create an 14kHz / 8bit / mono file
These are the instructions I've received. Maybe it is more clear now?
Old 11-28-2017, 01:34 AM
chrisdee's Avatar
chrisdee chrisdee is offline
You can do this with Audacity.
1) Select Tracks->Resample and write in 14000 as New sample rate.
2) Select File -> Save Other -> Export as Wav.
3) Select Save as type -> Other uncompressed files -> Encoding -> Unsigned 8-bit PCM.
Done.
Christian D Hagen | I7 Builds | PT/OS Compability Chart
Old 01-09-2018, 03:06 PM
Dan IceWood Dan IceWood is offline
"Sample Manager"
Old 01-11-2018, 06:17 AM
daeron80 daeron80 is offline
Audacity. Though, if you have iZotope RX, use it for the SRC, export at 16-bit, and then use Audacity to get it down to 8-bit. I have to do a similar thing for phone messages on other systems, only with mu-Law compression. Strange that we users of the two most professional audio programs have to resort to freeware to do certain types of paid work.
David J. Finnamore
Old 04-10-2019, 12:18 PM
deborosaurus deborosaurus is offline
BRING BACK 8-BIT EXPORT! I just upgraded from PT10 to 12 and I am regretting it more and more. Offline bounce is fine, but not when I have to use other programs to do final processing of files!! Absolute ********.
Best way to create mono tracks? realizment Pro Tools 10 6 10-06-2016 12:57 PM
one mono audio file when two mono tracks recorded bluerej Pro Tools M-Powered (Win) 0 02-06-2010 01:09 AM
one mono audio file when two mono tracks bluerej Pro Tools M-Powered (Win) 0 02-06-2010 01:06 AM
How to Create Stereo from Mono RussUK Virtual Instruments 1 08-03-2009 04:23 AM
How to combine 2 mono wav files into 1 mono file sjmonty Pro Tools TDM Systems (Mac) 10 11-13-2004 07:50 AM
