d con blinks and cure
just for other people's information, we just had one of our d controls fail by blining all the LEDs on just one fader car. all 16 channel's led indicator sections blinked on once every second. the faders worked and the leds displayed the correct info, but blinked.
cure: new LED switch mode power supply. I didnt see a thread addressing this issue so I thought you all would like to know.
Studio Troll |
Re: d con blinks and cure
Hi, thanks for the tip. Our Icon went into the same "mode" today. Where do you find the LED switch mode power supply? that would be a great help. Regards Bruce
Same thing started to happen here. Any info on how to get the new LED switch mode power supply?
Where are you located?
-M |
New Orleans Louisiana
Call Digidesign tech support and tell them you need an LED PSU. If you are still under warranty they will cover it... duh... and if you are out of warranty they will let you know what your options are.
It is pretty easy to replace yourself if you are tech savy. Otherwise, digi has a great field service team, and ARC network that can help you out. Maybe you have already done this, if not, I hope this helps. -M |
Just an FYI to anyone who needs this part. It worked fine and was pretty easy to replace, all screws, no soldering to do. The LED PSU went out on 3 consoles within several months. Guess they had a finite life span.
Call/email Digi if you are under warranty, if not they will refer you to the ProAxess site. |
DRY MIx cure | ajazzie | Pro Tools TDM Systems (Mac) | 10 | 06-02-2009 01:08 AM |
1394 led light blinks on 002 | Irenaus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-18-2008 08:08 AM |
MIDI "IN" LED BLINKS NONSTOP!! | Sonny Coates | MIDI | 3 | 12-27-2004 07:45 AM |
No Midi out 002 yet light blinks? | gibson_sg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 10-30-2004 01:03 PM |
New Cure CD? | Captain_Pants | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 07-06-2004 04:46 PM |
