Old 10-05-2003, 04:58 PM
underground underground is offline
Default Vocal Tracks
I'm new to recording and mixing vocals. I'm trying to get that thick chorus effect on the chorus.
I doubled and even tripled the track, just sounds louder, I want it to sound like two people.
Should the second track be slipped behind slightly? Any suggestions are greatly appreciated.
Old 10-05-2003, 06:30 PM
losttimestudios losttimestudios is offline
Default Re: Vocal Tracks
Little delay and detune the second track. Better yet, record second and third vocal track. Also Run vocal tracks thru outboard chorus unit. Lexicon MPX (pgm 89) sounds good.
Old 10-05-2003, 07:26 PM
Lost Time, thanks for responding, let's say I have three tracks. Do I process all three or jus the second and third and leave the original as is?
Old 10-05-2003, 10:08 PM
lawley lawley is offline
Make a copy of the track. Then shift/nudge the copy slightly forward - or - use a delay plugin.
Repeat with a second copy of the track.
Should give you a rich, full sound.
002 Rack, PTLE 7.0, G4 Dual 1.42, 1GB RAM, MidiMan Controller, Reason 3.04, OSX Tiger 10.4.2
Old 10-05-2003, 10:28 PM
Paul Cavins Paul Cavins is offline
Keep in mind that the listener has to have a feel for what the vocal part is doing. This means that he has to hear, in the vocals, a clear representation of the words and melody. Keeping this in mind, treat the first, the main vocal track like a normal lead vocal track, and process the others. If everything is altered, then what is left to lead the song?
Paul
I don't know karate but I know KA-RAZY!
Old 10-05-2003, 11:40 PM
JFreak's Avatar
JFreak JFreak is offline
try this:
1) make four (!) copies of your vocal track
2) pan those tracks something like -10,-5,+7,+12 (quite close to the lead track)
3) delay those tracks a little (something between 5-15ms), give each track different delay
4) detune those tracks a little (something between +/- 10 cents), each track differently
5) group those tracks together and apply effects if desired
that should be quite close to what "doubling" plugins are doing. of course it will sound better if you just make the singer do many takes and put those performances together. can't beat the real thing, can you
Janne
Old 10-06-2003, 05:11 AM
where02190 where02190 is offline
Use a chorus plugin or an outboard hardware effect umit. Simple and effective.
Old 10-06-2003, 06:51 AM
JFreak's Avatar
wanted effect was to make lead sound like "two" people, and chorus doesn't do that. though that is easy... i had the impression that the wanted effect was more like "doubling" than "chorusing", because it was said the lead should sound "like two people". my last post is about that and what you do if there's not a dedicated plugin available. (i know waves has a great doubling-plugin, but it's not available individually.)
Janne
Old 10-06-2003, 06:58 AM
Cliffy_Boy's Avatar
Cliffy_Boy Cliffy_Boy is offline
How do you detune? I can only detune in Autotune. What are you using?
Cliff Stendel
-iMac 5K 32g
-PT12. HDX
-HD I/O 8x8x8. -HD Omni -Avid S3
-API 2500 -API 5500 -UA 2-1176 -UA 2-610
-Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96
-Bricasti M7. -Joe Meek channel.
-Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more
-Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12
Old 10-06-2003, 08:10 AM
dBHEAD dBHEAD is offline
You can use the pitch shift plug-in in the Audio Suite to detune.
BTW, if it is really critical to make it sound like there are two people, couldn't you just have the singer overdub his/her vocal track? that would sound much more like two people than any "effect" could do.
Best Plugins to use for Vocal Tracks blueprs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-12-2010 07:56 AM
aon vocal aux tracks craiz730 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-10-2003 06:36 AM
The VOCAL tracks in a mix. Help? VincePro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 08-25-2002 08:29 AM
OT......Vocal Tracks? Punx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-30-2002 06:44 PM
comping vocal tracks? surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 12-19-2001 10:31 AM
