Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 03-20-2024, 12:25 PM
eekamouse1967 eekamouse1967 is offline
Default Question re connections
I have two 1394 firewire Motu 8Pre's and I want to add a 1394 Motu 828 to be able to use outboard gear. At this point I really only need one 8Pre. My questions is should I be connecting the 8pre and 828 via optical cable or firewire cable?
Thanks
Old 03-20-2024, 01:00 PM
Default Re: Question re connections
Probably I would use the ADAT connection, but I also question the need for hardware inserts(IOW, have you really thought it thru?) Here's my reasoning (which I'm sure many will disagree with): In my commercial studio in Nashville, I was not using an analog console and was set up to handle 32 IO, which was plenty for recording 5-6 piece bands. I spent a lot of money on some nice outboard gear(various mic pre's, Pultec's, LA2A,s, tube comps, etc) and tracked thru it every day. I then dropped some decent money on more IO, patchbay and cabling so I could do 8 hardware inserts. After I got it all wired and fully tested, over the next year or so, I used it exactly once I have nothing against it, but just didn't feel there was a net improvement in my mixes over staying in the box, and it eliminated any latency issues with the round trip out and back. Just some food for thought
Old 03-20-2024, 01:50 PM
Well come to think of it no I guess I hadn't thought it through that much.
I realize now that I see all this old gear I have had sitting around for years and I felt the need to make it available but you are right I probably will barely use it. Thanks for saving me a lot of headaches
Need help with C24 connections!! 3sixtymusic ICON & C|24 2 03-05-2013 04:46 AM
Connetions connections connections Maxaudio General Discussion 3 09-28-2011 08:50 AM
Technical Question: Help! What Connections do I actually need? BA Studios Pro Tools TDM Systems (Mac) 3 12-21-2008 10:00 AM
003 Connections - Quick Newbie Question Mike Borok 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-03-2007 08:08 PM
Question regarding router/ ethernet connections Dopamine ProControl, Control|24, Command|8 2 05-15-2007 08:42 AM
