Old 01-28-2024, 09:34 AM
Marsdy Marsdy is offline
Default Layout recall - frustrating behaviour?
Hi all
The following might be user error or a Eucon setting I’ve missed. Damned if I can find it though.
Here’s the issue… I have some layouts stored which I’m recalling from the layout buttons on the S3. My first layout shows every track in the session so each S3 fader in the layout is set to <auto assigned>. The second layout might be for all the VCAs in the session so each fader is assigned to an individual VCA track (or any other track for that matter.)
The problem is - if I go back to the first layout that shows all tracks (every fader <auto assigned>) - the S3 banks back to the top of the session - it doesn’t remember the selected/attentioned track on the surface, even though it is still selected in Pro Tools. This gets annoying very quickly as I’m constantly having to bank back to the track that was previously selected and visible on the S3, even though it is still selected in Pro Tools.
As I say, I might be missing a Eucon setting here.
Dave Marsden
UK
Old 01-28-2024, 11:15 AM
Mattiasnyc Mattiasnyc is offline
Default Re: Layout recall - frustrating behaviour?
There's an option in the "Layouts" tab in EuControl settings, at the bottom, which reads "Recall banked position with layout". At least with Nuendo I believe that box ticked means it will always return to the banked position you had when you saved the layout. So maybe try to deselect that?
It might not be what you're looking for though, but just a thought.
Old 01-28-2024, 11:17 AM
Thanks. That sounds like it might be the setting I missed! I’ll check it out in the morning.
Dave Marsden
UK
Old 01-31-2024, 07:56 AM
Forgot to follow up in this. That was indeed the setting I was after!
Dave Marsden
UK
Post module layout auto-recall not happening. emf1138 Avid S4/S6 6 06-21-2021 12:04 PM
spilled layout changes display layout kava Avid S4/S6 5 09-05-2018 12:42 AM
Internal - Recall Layout @tention Artist Series 0 06-04-2018 05:59 AM
Layout Recall Bug? hixonjames Avid S4/S6 2 01-03-2018 07:24 AM
Power Harness Recall of the Recall ! ChuckLogan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-21-2004 09:06 AM
