Old 12-17-2023, 06:25 PM
skylar_battles skylar_battles is offline
Default Decomposer Sitala - Mono version disappeared from Pro Tools
I mainly use Sitala and CR8 for drum programming in Pro Tools.
Preferably I like to use Mono versions of samplers which disables panning within the plugin itself, but still lets me use the track pan knobs on the track itself and other Mono Auxs where each separate element are routed to from Sitala.
With the mono version missing, I cannot listen to past work.
What is very strange is that the stereo versions loads into a stereo instrument track just fine and the plug-in is also in the plug-ins folder. But when I open an old session with the mono instance it says that the plug-in is missing even though it exists in the plug-in folder.
I've tried preference trash, workspace reset, and to reinstall the plug-in but no luck. What should I do to sort this out? I have reached out to them. Many thanks :)
EDIT: Just tried using AppCleaner to remove all files related to the plugin and to reinstall and put my license info again. Still only stereo
Pro Tools Ultimate 2024.3.1
MacBook Pro 16"
Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine
32 GB unified memory
1TB SSD storage
Ventura 13.6.4
Old 12-20-2023, 01:51 AM
tope d's Avatar
tope d tope d is offline
Default Re: Decomposer Sitala - Mono version disappeared from Pro Tools
Hi There!
I’ve just replied to your FB post. Has this happened in the past? Were you able to use them in mono on previous sessions?
Thanks
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 12-21-2023, 03:35 PM
Hey Tope! Forgive me, the issue only exists with Sitala. Just wanted to provide that info for people to be able to check out those plugins. CR8 seems to not be offered in mono, as I’ve never seen the mono version in Pro Tools.
I have used Mono Sitala in the past and now I cannot hear work made with it in past sessions. This hasn’t happened before.
Thanks!
MacBook Pro 16"
1TB SSD storage
Ventura 13.6.4
HTML code is On
Help - Pro Tools First projects have disappeared! dszalay Pro Tools | Intro Discussion 9 07-23-2022 11:24 AM
Pro Tools 11 Upgrade disappeared fullcode Pro Tools 11 2 03-25-2015 07:59 AM
Zoom tools disappeared? amptbuddy Pro Tools TDM Systems (Mac) 2 06-06-2010 08:59 AM
bx_digital V2 add Mono Version!! K.I. Pro Tools TDM Systems (Mac) 1 03-06-2010 03:27 PM
Grid disappeared in pro tools 4 Mickey_drmr Pro Tools TDM Systems (Mac) 0 03-01-2010 09:39 AM
