Having an issue with 23.6 / changing highlighted plugin
Hey All / Eddie
Hope you're well. I'm having an issue since I updated to Eucon 23.6. Running PT 23.6 as well. Whenever the EuCon app is open on my Mac (Monterey 12.5.1 Intel), if I add a plugin on a slot somewhere (with the keyboard/mouse), the plugin will usually flash up briefly only to instantly revert back to showing a previously highlighted plugin. I can't pinpoint exactly how it's choosing which plugin to take me back to, whether it's the penultimate most recently added plugin, or the previously highlighted one, I can't be sure. Not a huge issue when it's two different plugins, but for example Pro-Q 3 or Kirchhoff, which are on a lot of channels in a project, it's often resulting in me changing settings for the wrong instance of the plugin in a project. Have only just tried the PLIST hack you suggested in the pinned thread, I can report back if it's changed the behaviour. Thanks, Alex |
Re: Having an issue with 23.6 / changing highlighted plugin
Hi, Can you post a screenrecording of the issue you’re having? Checking on this further. Thanks -Tope
-Tope To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support www.topedomingo.com |
Thank you, -Tope
I'll try and suss it today and see if I can get a screen grab. Thanks. |
Was this ever resolved?
I'm getting the same problem - random plugins appearing when I either instantiate a new, or option-drag a plugin to a track. I've recorded a long video to see if I can identify what track they're coming from. Sometimes its the currently selected track, but other times its a track that was selected >3 tracks previously. Using PT2023.12, Ventura 13.6.3, Eucon 2023.11.0.121 and running an S3. Also have only selected 'Plugins' in the Attention most recently clicked DAW area, along with Auto-bank to selected track, and S3 Upper Knobs.
Pro Tools Ultimate 2023.12, HDX1 • Mac Studio M2 Ultra - macOS 14.2 |
I'm pretty sure it is already and will be in the next PT release.
Vol/Pk/Dly Changing Issue | Roulette Records | Pro Tools 12 | 8 | 01-25-2018 10:31 AM |
Bit-Changing Plugin | jgiannis | Pro Tools 10 | 1 | 03-17-2016 11:45 AM |
Changing the Plugin Folder | BrandonMillerAudio | macOS | 2 | 08-30-2014 04:24 AM |
Why is a specific plugin highlighted on my Inserts list? | PTLExp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-17-2010 08:18 PM |
Changing Transport issue | butter_lover | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-07-2003 05:27 PM |
