Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 02-25-2023, 02:17 AM
kt90 kt90 is offline
Default Digi 003 with Audient iD 44mkii
hi people
Ive just purchased an audient iD44 mkii. I am trying to add this to the 003 desk as extra inputs. I have a Toslink cable. connected from the audient out to optical in on the 003. Basically I want to use the preamps from the audient and still have use of the desk for a control surface. Is this possible? Or do I just open the session and use the audient as the playback engine for recording. then when all the audio is recorded change the playback engine to the digi 003.
When I want to bounce down I want to try use the audient converters to compare. Any help would be muchly appreciated. I am using windows 10
Thank you
Keith
Old 02-25-2023, 07:14 AM
its2loud its2loud is offline
Default Re: Digi 003 with Audient iD 44mkii
A response has been given here
https://duc.avid.com/showthread.php?t=423648
Audient Evo 16? EGS Windows 14 02-06-2024 12:18 AM
Audient ASP880 in Audient ID14MKII ADAT Weak Signal cj_Db Third Party Interfaces 12 07-07-2021 06:26 PM
Urgent help - audient asp008 aes and digi 192 karljohnson Pro Tools TDM Systems (Mac) 2 05-09-2010 06:44 PM
pro control vs audient speedyk5 Pro Tools TDM Systems (Mac) 0 01-23-2002 04:21 PM
