S1 faders for send levels
Is there a simple way to move the send faders onto the channel faders of the S1?
Re: S1 faders for send levels
I'll be more clear:
Fiip select Aux (use Page buttons to switch between sends) Send will be on fader
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 Last edited by BScout; 12-30-2021 at 04:31 PM. Reason: clarity |
is there a way to spill all sends of a channel to available faders,
instead of having all sends under 1 fader and paging between different sends? |
Unfortunately no. Not on the S1. But this would be a cool feature.
If you have a tablet for your S1, you can go into Channel mode, select Sends, then control any of the send levels and mutes by the touch screen.
Mark Ettel C.A.S. |
Select the channel you want the sends spilled from. Select channel mode (shift+flip) Select Aux Select Flip Sends will spill from send a down
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Ah! Duh. Of course! Thanks BScout.
ohhh this is beautiful :) thanks!
Wouldn't it be amazing if it was possible to hit a soft key and it would run a macro that did:
Select channel mode (shift+flip) Select Aux Select Flip ??? |
Coming next release
Trying to bring up Send Faders | Valour Winds | Pro Tools 10 | 2 | 01-06-2014 04:06 PM |
Bug with send levels in PT 11? | Gammon2006 | Pro Tools 11 | 9 | 10-03-2013 02:55 PM |
Aux send Faders in PT LE | trumpman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-01-2010 08:07 PM |
How to group Send Faders | ivan4217 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-03-2008 06:34 PM |
Group send faders in LE 7.3 | 4times4mil | Tips & Tricks | 2 | 12-14-2006 12:27 AM |
