Old 10-26-2017, 04:53 PM
Impervious Impervious is offline
Default Avid Artist Series Bank Nudges Instead of Bank
Avid Artist Series won’t bank properly. The bank soft key nudges tracks instead of banking them. They were working fine earlier today.
I’ve tried restarting the controllers and the computer. Does anyone have any advice?
Old 10-27-2017, 05:27 AM
Not Solved.. Please help
Last edited by Impervious; 10-27-2017 at 07:30 AM. Reason: I thought it was solved
Old 10-27-2017, 07:13 AM
simonjewel's Avatar
simonjewel simonjewel is offline
Default Re: Avid Artist Series Bank Nudges Instead of Bank
Originally Posted by Impervious View Post
Solved
How did you solve it?
Mac Pro 2x2.8 ghz Intel Zeon, 20 gig ram, Yosemite 10.10.5, Pro Tools 10,11,12.7.1, Logic Pro X 10.2, UA Apollo 16 quad, UA Octo Pcies, Dangerous Music 2 Bus, Antelope Audio Satori, Lynx Studio Hilo, Neve 542, Neve 511, API 505 DI, Bettermaker CV502. Avid Artist Mix, Avid Artist Control, Softube Console 1 mk11.
Old 10-27-2017, 07:28 AM
To be honest. I open a new session and created a bunch of tracks to bank through & things work as they should.
It has something to do with assigning tracks to faders. If I remove all assignments, the controller will bank as it should. If I use assignments, the controller banks track by track.
So therefore, it is not solved. I’m a bit dissatisfied with my purchase of the Avid Artist Series. It has great potential but it is a bit buggy.
Old 10-27-2017, 07:39 AM
I PM’d EddieJones. Hopefully he’ll chime in soon.
Old 10-27-2017, 07:44 AM
EddieJones's Avatar
This could be due to a change in 3.7. Previously in earlier versions, say you had just a Mix and you assigned 3 faders to it. When you banked it would still bank by 8, so you would always miss 3 of the tracks. Now when you bank it (should) bank by the available number of strips that are not assigned. I think this may have something to do with it?
Old 10-27-2017, 07:49 AM
You know Eddie, that sounds spot on! I currently have 8 faders assigned to tracks.
I just tested it & yes if I remove 4 assigned tracks, the controller will now bank by 4.
I’m actually running EuControl 3.3.2 with PT 10.
So as of now this is expected behavior?
Old 10-27-2017, 07:55 AM
EddieJones's Avatar
This change I just posted was in v3.7.
3.3.2 is before my time so not sure why it's doing that with that version, if you have multiple Mixes it should still bank by 8.
Old 10-27-2017, 08:03 AM
Yeah.. strange.. I would run 3.7 but it won’t run properly on OS X Mavericks & any version higher than 3.3.2 the meters on the Artist Series are not visible.
Old 10-27-2017, 08:12 AM
EddieJones's Avatar
I think the meters issue is when we switched to the new selectable meters in PT11...Eucon had to change to match.
Can we get the Dock to bank the Artist Mix? Anthony_Anz Avid S1, S3, Dock and Control App 2 05-11-2017 09:52 AM
Mix Window Follows Bank Selection - Artist Mix HowlingWolfStudio Pro Tools 11 4 01-17-2014 09:48 PM
Artist Mix Auto Bank To Selected Fixed! Chief Technician Artist Series 13 04-23-2013 02:12 PM
Bank D on SC48? Future Custom Bank perhaps? digidesigner VENUE Live Sound Systems 1 01-11-2010 07:20 AM
Anyone using Filter bank-Compressor bank c.evans 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 12-13-2001 10:16 PM
