Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | Intro Discussion
Old 01-01-2016, 06:36 AM
Muddy-T's Avatar
Muddy-T Muddy-T is offline
Default Re: Pro Tools First error -6117
Good news is, I got rid of the dreaded -6117 loop. Bad news is, I'm still not sure what actually caused the problem in the first place.
Here's what I did;
- Completely un-installed PT|First (including Application Manager, plug-ins, project cache, everything)
- Thrashed every single file and folder that contained 'Avid' or 'Pro Tools'.
- Ran CCleaner to get rid of anything left behind.
- Re-installed ASIO4all
- Re-installed the latest version of PT|First
That did the trick.
For first time users of PT; make sure you optimize your system for PT according to these guides; http://avid.force.com/pkb/articles/T...oting/en367983
Additional tip for users on PC;
- Right-click on the white speaker icon located in the system tray on the Windows task bar near the clock.
- Choose Playback Devices
- Select the audio device that you would like to adjust
- Click Properties
- Choose the Advanced tab
- Uncheck the 'Allow applications to take exclusive control of this device' box (both boxes will be disabled now)
- Click OK.
- Repeat these steps for any additional devices on the Playback tab
- Repeat these steps for any devices listed on the Recording tab.
- Reboot your computer to affect the changes.
Hope this helps.
"Don't look; listen!"
At work; 2013 27" iMac/i5/2.9GHz/8GB, OSX 10.8.5, PT 10.3.6
At home; Custom Made Mac (Hackintosh) i7 (3770 "Ivy Bridge")/3.4GHz/32GB@2400MHz, Samsung SSD 840 EVO 250GB System Drive, Samsung SSD 750 EVO 250GB Audio Drive, OSX 10.10.5, PT 12.8.1
Old 01-20-2016, 06:12 AM
kavorkakavorka kavorkakavorka is offline
I also have the same problem. Win7, PT First. I believe I have tried all the above-mentioned remedies. ASIO4ALL, reinstall, N at upstart, etc.
When I start PT First I get:
"AAE error -6117 was encountered"
"The selected audio device could not be initialized. Please choose another audio device."
How do I choose another Audio Device?
Best
/P
Old 01-20-2016, 01:09 PM
DigiTechSupt's Avatar
Hello kavorkakavorka,
May I know what operating systems you installed PT|First.
Regards,
RC
Avid Audio Tech Support
Support FAQ
Old 02-02-2016, 06:23 PM
TheCaveMan's Avatar
TheCaveMan TheCaveMan is offline
Again, another thread w/ the very same issue and still no fix? Really?
Old 02-04-2016, 11:39 AM
Jason 29 Jason 29 is offline
Brand new to PT First as of two days ago, same issue, find all these threads, and then your comment was icing on the cake. I wanted to switch to PT after using Sonar for the past 15 years, I really did...now... well....we'll see
  #16
Old 02-06-2016, 10:37 AM
Muddy-T's Avatar
FYI;
AAE error -6117 returned after connecting a new interface (Focusrite Scarlett 2i4)
Did a quick repair install of PT|First and all was good again.
  #17
Old 03-18-2016, 05:11 AM
TheWookieWay TheWookieWay is offline
But were you stuck in the AAE -6117 loop when you did this, Muddy?
  #18
Old 03-18-2016, 06:32 AM
Muddy-T's Avatar
Yes.
  #19
Old 03-18-2016, 01:54 PM
Defier Defier is offline
Best advice for ASIO4ALL anot get that PT -6117 error...
Be sure to have install ASIO4ALL before any other software including Pro Tools.
Thx.
  #20
Old 04-15-2016, 04:00 PM
Unnamed Unnamed is offline
Default [SOLVED] Pro Tools First error -6117
Hello all,
I think I could finally figure out the cause and found a solution for this annoying thing. I created a new thread for it, but as this thread here is probably the first result you'll get from Google, I'm posting it here too. Here's the solution thread.
Hope it helps.
PT First AAE Error 6117 epicsaxman13 Pro Tools | Intro Discussion 10 06-18-2016 05:28 PM
Pro Tools First Error -6117 MinusE Pro Tools | Intro Discussion 1 08-31-2015 01:36 PM
Audio Error 6117 PT First laurabeele Pro Tools | Intro Discussion 3 08-13-2015 11:34 AM
Unable to reacquire hardware and DAE error 6117. Please help TheSmackPanda Pro Tools 10 2 06-16-2015 02:02 PM
