Error (-9514) on 10.3.2 Update
I'm having this issue with loading Pro Tools after upgrading to 10.3.2 and it seems a few people are having the same problem. 'Could not allocate memory for the disk cache. Try lowering your disk buffer (DAE buffer), disk cache size, or engine voice count. If you got this error on launch, delete your prefs and try again.' (-9514) I've deleted my prefs and this hasn't helped, I've also tried running as Administrator with no luck either. Any other suggestions? I struggled for a long time with an ilok issue in Pro Tools 9, this was then fixed when I upgraded to Pro Tools 10 but now that issue has now returned with this upgrade. I get an error saying 'ilok not found, please insert and try again', my 'fix' for this is to double click the Pro Tools icon at the same time as inserting the ilok and it works as before (I used to have to do this every time). Unfortunately, it loads as far as 'DAE Loaded' and I get the above error message and when I click 'ok', it shuts down Pro Tools. I've tried a complete reinstall with no change. I can just reinstall Pro Tools 10 from a disk and carry on as usual but as I have free upgrades it would be good to see what's new. Any advice? Here's my Sandra report: Computer Model : HP s5760uk Workgroup : WORKGROUP Processor Model : AMD Athlon(tm) II X4 640 Processor Speed : 3GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 64kB, Synchronous, Write-Back, 2-way, Exclusive, 64 byte line size L2 On-board Cache : 4x 512kB, ECC, Synchronous, Write-Back, 16-way, Exclusive, 64 byte line size Computer Mainboard : PEGATRON CORPORATION 2A99 BIOS : AMI 6.16 03/18/2011 Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 4GB DIMM DDR3 Chipset Model : AMD F10h Athlon 64/Opteron/Sempron HT Hub Front Side Bus Speed : 2x 1GHz (2GHz) Total Memory : 4GB DIMM DDR3 Channels : 2 Memory Bus Speed : 2x 670MHz (1.34GHz) Memory Module(s) Memory Module : Hynix (Hyundai) HMT125U6TFR8C-H9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Hynix (Hyundai) HMT125U6TFR8C-H9 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Video System Video Adapter : ATI Radeon HD 5450 (80 SM5.0 650MHz, 512MB DDR3 2x800MHz, PCIe 2.00 x16) Graphics Processor OpenCL Processor : Cedar (160SP 2C 650MHz, 256MB) Compute Shader Processor : ATI Radeon HD 5450 (80SP 650MHz, 503.4MB 2x800MHz) Storage Devices Seagate ST3750528AS (750.2GB, SATA300, 3.5", 7200rpm, NCQ) : 699GB (C:) (D:) WD Ext HDD 1021 1TB (USB) : 932GB (H:) Multi Flash Reader (USB) : N/A (F:) hp CDDVDW TS-H653T (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:) Logical Storage Devices SYSTEM : 100MB (NTFS) Elements (H:) : 932GB (NTFS) @ WD Ext HDD 1021 1TB (USB) OS (C:) : 686GB (NTFS) @ Seagate ST3750528AS (750.2GB, SATA300, 3.5", 7200rpm, NCQ) HP_RECOVERY (D:) : 13GB (NTFS) @ Seagate ST3750528AS (750.2GB, SATA300, 3.5", 7200rpm, NCQ) Removable Drive (F:) : N/A @ Multi Flash Reader (USB) Optical Drive (E:) : N/A @ hp CDDVDW TS-H653T (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : HP MCP61 LPC Bridge LPC Legacy Controller 1 : Asus F8000 Audio Device : HP MCP61 High Definition Audio Audio Codec : Realtek Semiconductor Realtek 662 High Definition Audio Audio Device : MSI Manhattan HDMI Audio [Mobility Radeon HD 5000 Series] Disk Controller : HP MCP61 SATA Controller Disk Controller : HP MCP61 SATA Controller USB Controller 1 : HP MCP61 USB Controller USB Controller 2 : HP MCP61 USB Controller SMBus/i2c Controller 1 : nVidia MCP5+ SMBus 1 SMBus/i2c Controller 2 : nVidia MCP5+ SMBus 2 Printers and Faxes Printer : Send To Microsoft OneNote 2010 Driver (1200x1200, Colour) Printer : PDF Complete Converter (2400x2400, Colour) Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : HP Deskjet F2100 series (1200x1200, USB, Colour) Fax : Microsoft Shared Fax Driver (200x200) Peripherals Media Player : () Network Services Network Adapter : NVIDIA nForce 10/100 Mbps Ethernet Wireless Adapter 1 : 802.11n Wireless LAN Card (802.11g (ERP), AES-CCMP, 65Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 4.9 Cheers. |
Re: Error (-9514) on 10.3.2 Update
I had the same issue . I ended up re installing the update . And everything works fine now.
focusrite liquid saffire 56 ,digi rack 02/ presonus digimax 8, allen heath gl2432, mobo asus m4a88td-v evo/usb3, AMD 1075 sixcore corsair XMS3 ddr3 4g (x4) western digital 1tb hard drive 7200rpm(x 2), 680watt power supply no name, windows7 home premium 64 bit |
Yeah, I've tried a complete re-install but still no joy.
Thanks anyway. |
Martin11, I was just about to post the exact same thing here and noticed you beat me to it. I have the same error as you but different system.
I think its something with 10.3.2. -- I have been using 10.1 since it basically came out of avid. I am usually not one to jump on any upgrade until its been out and proven.. Because 10.1 was working so well for me, I never rushed to put 10.2 on my machine, in fact I skipped that version altogether.. But recently, I was trying to troubleshoot some flakey MIDI stuff and decided to try 10.3.2.. So this morning I installed it, got the same error as you.. Tried to take one of the other posting on this thread about just reinstalling and seeing if the issue is resolved. I did NOT resolve the issue. So for me, bottom line was 10.3.2 always gave me this issue. So I decided to backup 1 version, I installed 10.3.1 and .. Bingo, it works as designed. Played the same old song files and no crazy errors. -So my fix is just staying with 10.3.1.. Not sure the 10.3.2 would really offer me something I couldn't live without.. Hope this helps.. joe |
Thanks Joe,
Yeah, think I'm going to just reinstall 10 from disk and just ignore the update. Pro Tools 10 worked fine for me and I was happy with it. Just hope this doesn't affect future upgrades! Cheers for your reply. Martin |
Re: PT10 shows not connected 1 (mono), not connect 2(mono)
Hi, can some one please help me out I just upgraded to PT 10 with alot of excitement, unfortunately my digi 003 analog input cant be seen. when I try to insert mic input , PT10 shows not connected 1 (mono), not connected (mono) extra.
Hoping for any ones urgent support |
This works:
Success!!! 1. Uninstalled Protools 10 2. Removed 3rd party plugins to my desktop from the plugins folder 3. Completely deleted everything that has to do with AVID 4. Enabled DEP during installation using Avids Troubleshooting link below. http://avid.custkb.com/avid/app/self...411#Enable_DEP 5. Restarted PC 6. Installed Protools 10 7. Right Click Protools 10 Icon then go to properties. Go to the compatibility tab and check the box under privilege for Run this program as an administrator 8. Boot Up and enjoy!! 9. Doesnt work, try disabling DEP 10. Dont forget to add all your 3rd party plugins back in your new plugins folder. Hope this works for everybody else having issues. And I turned off DEP when I started to use PT after the reinstall and restart of pc. The link is broken, but heres how: Right click on computer/properties/advanced system settings/under performance - settings/ and there you go! -B |
TSK1, you need to start your own thread instead of camping on to somebody else's. Especially when yours has nothing to do with theirs. Thank you.
-9514 error... Going out of my mind | mesaone | Windows | 6 | 01-13-2014 09:28 PM |
DAE buffer -9514 error | jonwade92 | Windows | 14 | 08-01-2013 12:16 PM |
Error -9514 with ProTools 10.3.4 on win 8 | hattom | Windows | 2 | 03-20-2013 06:55 AM |
PT 10.3.3 Error -9514 on Launch | yorkshirepud | Windows | 10 | 01-06-2013 10:46 AM |
Pro Tools Startup Error -9514 | frank1985 | Pro Tools 10 | 3 | 12-05-2012 03:09 PM |
