Old 04-23-2009, 10:37 AM
The Chinese The Chinese is offline
Default Control 24 w/ USB->Ethernet adapter?
Anyone have experience with this? I have a situation where I am running ProTools and use 1 nic for production network, one nic for XSAN Metadata (No not for use with PT, just for storage), and need a 3rd nic for the Control 24. I have a P7R4 Expansion chassis that has been modded with Magma parts to PCI, and got a PCIe->PCI host adapter. We have some Apple PCIx ethernet cards, and also some other random PCI ethernet cards, but they do not work for some reason.
Here's my Config.
Mac Pro Nehalem 2x2.26 Quad core 16G RAM. Magma P7R4 expansion modded with P7NE board set. PTHD2 Accel.
Everything runs very smooth, just want to get this nic situation figured out.
Thanks,
Todd A.
Old 04-23-2009, 11:04 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Control 24 w/ USB->Ethernet adapter?
Here's my Config.
Thanks,
Todd A.
I have run my control 24 on a shared network, using an ethernet expander/hub but it did slow the response of the control 24.
I guess if the usb adapter is seen by the mac as an ethernet port then it should be accessible from the peripherals menu.
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-23-2009, 11:26 AM
Craig F Craig F is offline
I tried it but was not able to get it to work
But I put minimal effort into it
Thank you,
Craig
Old 04-23-2009, 11:55 AM
JFreak's Avatar
JFreak JFreak is online now
Get a good ethernet switch (OSI layer 2) instead of hub (layer 1) and you should get less lag.
The switch will analyze frames coming in on its entry ports and filters the data in order to focus solely on the right ports. So effectively it redirects data flow to the most suitable machines, based on certain elements found in the data packets. In other words, it inspects the source and destination addresses of the messages, and creates a table that lets it find out which machine is connected to which port on the switch. Once it knows the destination port, the switch only sends the message to the right port, and the other ports are then free for other transmissions which may be taking place at the same time.
Come to think of it, this kind of switch might already be operating on layer 4 of the OSI model. But anyway, that's the principle. Never use hubs, nowadays proper switches are not that much more expensive.
Janne
USB-Ethernet adapter andreasaidu Artist Series 6 02-18-2011 09:16 AM
USB to Ethernet Adapter with Euphonix mcmix gsilbers Artist Series 3 05-04-2010 10:57 AM
Will Control 24 work with USB to ethernet adapter ? VIKING ICON & C|24 3 08-30-2009 03:13 PM
USB to ethernet adapter Craig F ICON & C|24 10 12-18-2007 11:11 AM
Procontrol, USB to ethernet Adapter spigots ProControl, Control|24, Command|8 4 02-21-2003 04:49 PM
