Old 09-01-2020, 02:24 AM
kava kava is offline
Default New Machine - unable to play - Not enough DSP?
I'm just setting up my new Mac Pro 2019. Fresh install of Catalina 15.5, Protools 2020.5 HD Driver 2020.5 - two HDX Cards.
Cannot play anything - Just get …"Not enough DSP for the mixer" anytime I try to play, solo or change /in/output. Digitest runs fine.
what's wrong??
EDIT: Protools also crashed when closing sessions.
Mac Pro 2019 16-Core, 144GB Ram, OS X 10.15
ProTools Ultimate, 2x HDX
NTP Penta720 I/O + 192 HD I/O + SSL Madi Link
Sync HD, Dolby Atmos RMU
S6 - M40 - 32channel.
Filmpost at cosmix studios vienna
http://www.cosmix.at
http://www.tom-kava.com
Old 09-01-2020, 02:26 AM
JFreak's Avatar
JFreak JFreak is online now
Default Re: New Machine - unable to play - Not enough DSP?
There is a good thread for 7.1 issues, maybe you will find your answer there?
Janne
Old 09-01-2020, 03:05 AM
thanks, I already scrolled through that thread. No info on my situation,
I already tried trashing prefs and pluginfolder etc... still "no dsp"
Old 09-01-2020, 03:10 AM
JFreak's Avatar
Okay then, so back to basic troubleshooting.
Remove one of the cards and find a slot where you can get HDX1 working as it should. Then replace it with another card and see if the second card functions as expected. Then install second card to adjacent slot and try again.
Janne
Old 09-01-2020, 03:41 AM
I can only use one HDX Card at the moment - the other one is not avaliable at the moment.
I tried the remaining one in slot 5 and 6 - makes no difference.
The card used to work without a problem yesterday in my TB-Sonnet chassis connected to my old mac pro 2013.
Old 09-01-2020, 03:43 AM
JFreak's Avatar
Alright then, you need to contact Avid Support with your issue. Next PT version is likely around the corner so that may (or may not) fix it.
Janne
Old 09-01-2020, 05:37 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Did you use a HDX2 setup in the Sonnet chassis or was it also HDX1?
Old 09-01-2020, 06:12 AM
I used a HDX 2.
interestingly it now works!
I put one HDX card in the old Sonnet chassis - connected that to the new mac pro and started protools - card worked.
I then put the card back into an pci slot of the mac pro - and suddenly it worked to.
before that I had the card in all possible slots in the new mac pro and it never worked. Could It be that some kind of firmware update happened to the card when it was recognized while in the TB-Chassis?
Old 09-01-2020, 06:13 AM
JFreak's Avatar
Possibly, if you opened latest PT with the card powered on. But unlikely, as there are more trouble reported regarding updating firmware on chassis. Glad to hear you got it working anyway
Janne
Unable to play videos S1ephen Windows 1 01-11-2016 06:31 AM
unable to play? tonejunkee macOS 0 03-14-2012 01:37 PM
Cue + Play w/Machine Control Problem Esus Post - Surround - Video 0 01-28-2008 02:33 PM
I can not get Sony DVW M2000 to play with Machine Control Tim Regan Pro Tools TDM Systems (Mac) 3 05-07-2007 07:48 PM
Unable to play wav wave files in 6.4 shutupandshave 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-15-2004 02:52 PM
