Old 07-09-2019, 11:59 AM
tomhartman tomhartman is offline
Default Sync PT and Other DAWS?
Does anyone know how I would use PT as a slave so I could do midi in something like Cubase or DP, and then record the VIs back into Pro Tools? I would do the tempo map in PT and export it to the other program so we are all happy with the tempo, but not sure how they would connect to one another...
This would all be on the same Mac...
Thx
TH
Old 07-09-2019, 02:07 PM
xrekcor's Avatar
xrekcor xrekcor is offline
Default Re: Sync PT and Other DAWS?
Thx
TH
Running 2 DAW’s on 1 puter and I suspect 2 or more interfaces? Don’t think you’ll get away wif doing that...
Rob
MBP 15” 2018 macOS Big Sur 11.6.8 Touch Bar and ID
2.2GHz 6 core 8 gen Intel Core i7 processor (TB’s to 4.1GHz)
32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard
Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II
........and a bowl of M&M's
Old 07-09-2019, 02:17 PM
grayter1 grayter1 is offline
Thx
TH
It can be done using Rewire. I've done it with Ableton and PT. The gotcha IIRC is that you have to print the VI's in the source DAW. I was never able to run live VI's in the source DAW while sending via Rewire. It must be audio only.
In general, I've had multiple DAW's open on the Mac thanks to Core Audio like Reaper and Studio One. I've done this when transferring songs (midi files) from one to the other when I've had to reference things in the original sequence. However, using Pro Tools can be trickier because sometimes PT will take over the driver. Now that I've switched to Windows 10, the flexibility of Core Audio is the only thing I miss about Mac OS.
tg
Mac Studio (2022) M1 MAX / 64GB / 2TB HD / macOS Ventura 13.6.5 / RME BabyFace Pro FS / SSL UF8 + UF1 + UC1 / Roland SYSTEM 8 / Kontrol S61 mk3 / Pro Tools Studio 2024.3 / Nuendo 13 / Reaper 7 / Komplete 14 / Omnisphere / Keyscape / Trilian / V Collection X
Old 07-09-2019, 02:18 PM
sw rec sw rec is offline
I got 2 separate computers to sync once using nothing but a MIDI connection between the two. Long time ago...Pro Tools 5.xx and SAW Pro.
Old 07-09-2019, 09:02 PM
xrekcor's Avatar
You might be able to do the same via time code sync that would be more stable sync. I pretty sure PT has time code just not sure about Cubase but I would assume it does too. That way you could sync the two DAW’s transport where one triggers the other. Not sure if that is doable but might be worth investigating.
Rob
Old 07-10-2019, 01:14 AM
JFreak's Avatar
JFreak JFreak is offline
PT and Logic sync together via MTC pretty nicely
1) go to audio midi setup and enable IAC Driver
2) go to PT setup / Peripherals / Synchronisation and set MTC reader port to IAC Driver Bus 1, then enable sync on the transport panel
3) go to Logic, right-click synchronisation control bar icon and choose synchronisation settings. choose midi tab and under MIDI Time Code, check transmit and choose IAC Bus 1
4) enable sync in Logic
If it doesn't work properly, you probably have frame rate mismatch.
Janne
iPad DAWs Righty27 Pro Tools 10 7 12-20-2012 03:31 AM
Using 003 Factory with other DAWs bendybones Pro Tools TDM Systems (Mac) 4 03-04-2010 04:34 PM
Flood of new DAWs? TCM General Discussion 6 10-01-2009 05:31 PM
PT HD and 3rd Party DAWs brobb Pro Tools TDM Systems (Mac) 1 03-07-2002 02:01 PM
Other DAWs... trkkazulu General Discussion 1 01-25-2002 05:56 AM
