Input monitoring
Hi, new Pro Tools 11 (Native on PC) user here, coming from Cubase/Nuendo. I tried recording something to a click and, when I played it back, it was out of time. I'm guessing because of input monitoring. I have an RME UFX card that I can use for monitoring. Can someone explain what my settings should be for monitoring the lowest latency possible?
Re: Input monitoring
There is a known bug with PT11 that tracks recorded that are not at the TOP of the edit window when recording will have a large amount of latency added to them. They are working on a fix and you can find the workaround link in the last two pages of the thread I linked it to. Good Luck! |
I would say though to start with the basics first and make sure to keep your hardware buffer setting at around 64. With my RME fireface, I would set this inside the Total Mix software. I believe you have the same or similar with the UFX.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
Thank you! I think that is my problem exactly. For the "industry standard" I'm finding a lot of things lacking in Pro Tools
Input monitoring in PT 11 ? | queemacarthur | Pro Tools 11 | 6 | 04-09-2013 09:42 AM |
Input monitoring | ROBB007 | macOS | 7 | 04-08-2013 05:07 PM |
Input Monitoring | ROBB007 | macOS | 6 | 02-16-2013 11:20 PM |
Auto input/input only monitoring failing in PTLE 8.0.4 | miketeachesclass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-11-2012 08:48 AM |
Auto Input monitoring / Input only monitoring - Alt+K | AdamPT8 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-09-2010 10:50 AM |
