Why does the PT VU meter default to 0VU = -14dBFS
When you look under Advanced Meter Type Settings and set the Meter Type to VU, the "0 VU" is, by default, equal to -14 dBFS.
Isn't this normally -18dBFS, or am I misunderstanding something? Why does PT have it set to -14? |
Re: Why does the PT VU meter default to 0VU = -14dBFS
Probably a combination of things went into this. Somebody in the past decided that 14dB was the right amount of peak to RMS headroom for modern pop/rock production. Avid followed suit and made their LE and entry level interfaces with 14dB headroom above +4dBu. So 0VU=+4dBu same as it always has.
Digital VU is -18 dbfs
VU (A bit more like RMS as mentioned above) is -14 Both are adjustable.
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
I may be mis-remembering but I am thinking that the -14 is a carry over from older Pro Tools that used less than 24 bit processing and they just sort of left it that way even when it was no longer necessary, just to make things equal or something.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
Wow. I had no idea that 0 VU = - 14dbFS. I thought it was -18 dbFS everywhere. Is the 0 VU = -14 dbFS a Pro Tools-specific thing, or is that an industry standard?
Has nothing to do with Pro Tools. Has everything to do with the audio interface. Sent from my iPad using Tapatalk
0VU = +4dBu
How that relates to dBFS is arbitrarily set by the user depending on how much headroom you want above your 0VU point. Most studios in the US set 0VU = +4dBu = -18dBFS, but in broadcast -14dBFS is a common set point, and in many classical recording environments it's -20dBFS. It's up to the user as to how they want their I/O calibrated, but personally I find -18dBFS the best compromise.
In Canada, -20 dBFS is the common set point for broadcast. I've never heard of a broadcaster being calibrated to -14 dBFS.
Matthieu Bourque PT Ultimate 2022.10 on macOS 12.6.1 |
LE hardware and the HD96 interface have -14, HD192 and newer have -18, only film/video are using -20
The VU reference value is determinated by the audio interface, the easy formula to get your reference value is check the specs of the interface used, example:
ua apollo max output level = +20dBu. so the 0 VU= +4dBu is -16dBfs=0VU just need to check the max output and then rest 4dB and thats your reference value, the -18dBfs it's a "standarized" but not 100% accurate, check some plugins manual to know the reference value for gain stage. |
VU meter set to -14dbfs | abt | Pro Tools 2018 | 3 | 01-31-2018 10:00 AM |
Why are the 882 converters calibrated to -14dbFS? | HSLand | Pro Tools TDM Systems (Mac) | 1 | 01-05-2015 08:10 PM |
why external vu meter/ plug-in vu meter differ? | sjtae | macOS | 8 | 06-06-2012 05:50 PM |
Inserts affecting send meter but not channel meter? | Kbrinson85 | Windows | 1 | 05-01-2012 07:00 AM |
PTHD8 cpu meter vs task manager cpu meter | MEAT | Pro Tools TDM Systems (Win) | 5 | 01-02-2009 05:17 AM |
