Where to put slate VTM?
OK guys im using VTM just wondered where people put it on their inserts. Do you guys put it as the very 1st one on the very last one. Where was it designed to go as its acting like a tape machine
for example i used it like this last night on a guitar track 1st was McDSP AC1 2nd was Waves SSl Channel 3rd was Slate VTM This track then went to a guitar sub mix but i didnt put VTM on that, would you guys advise putting it here as well, if so would it be the first insert or last. I do have VTM on my master buss as well though where it is last in the chain
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
Re: Where to put slate VTM?
I don't think there is any right or wrong!
Here is my usage: usually on guitar bus, after Slate VCC. On my masterbus I still prefer McDsp AC2 Sometimes I use http://varietyofsound.wordpress.com/...-the-kvr-dc09/ with the FXpansion wrapper.
002R BLA mod and Mbox mini 2, PT 11.3.2, HD Native, HD IO 16x8x8, PT 2018.7, Win 10 Pro 64, Asrock X99 Extreme6/3.1, i7-6850K, 32 GB Ram, SSD system drive, ssd audio drive |
I want to run it like a tape machine would be run
Raoul Crane
the sig comes from the tape into the console,
so, it would be first. (and, in keeping with the analogue-gy console emu's would be last.) altho, reversed on the master strip; console emu first, then mastering tape last. e
ihatetyping |
Depends on what you're trying to simulate. If for example you're trying to have a band recording through a console to tape, then mix from the multitrack tape machine to a 1/4" master tape, and then turn that master tape in to a production master, using McDSP in this example you'd do the following : All Audio Tracks Slot 1 = AC1 (recording the musician through the "desk" pre-amp) Slots 2 & 3 = Filterbank & Compressorbank (if you are "printing" any tone shaping to "tape") Slot 4 = AC2 (the same machine / tape formulation on every audio track) Slot 5 = AC1 (feeding the recorded performance off the "tape", back through the "desk") Slots 6 & 7 = Filterbank & Compressorbank (for any additional shaping of the mix) All Aux Tracks Slot 1 = AC1 (returning any channel sends through the "desk" pre-amp) Slots 2 & 3 = Filterbank & Compressorbank (for any shaping of the mults / fx returns) Master Track Last Slot = AC2 (only necessary if you're trying to simulate a 1/4" mater tape of the final mix) Production Master Slot 1 = AC1 Slots 2 - 8 = any tone / dynamic shaping plugins you require Slot 9 = AC2 Slot 10 = Dither |
Think I might try this ^ and see how it sounds Carl
Raoul Crane
FS: Slate VCC, Slate VTM, Soundtoys Radiator | apesong | Buy & Sell | 10 | 05-01-2014 03:01 PM |
Slate Digital and Steven Slate Drums AAX | DHL | AAX Plug-ins | 6 | 04-22-2013 12:50 PM |
Slate VCC & VTM | bonzerboy | General Discussion | 2 | 11-11-2012 03:22 PM |
SLATE VCC & PT 9-HD (Mac OS) - how is it? | MixerGuy | macOS | 2 | 10-04-2011 10:01 PM |
Slate vcc | Fullsound Recording | Pro Tools TDM Systems (Win) | 5 | 09-30-2010 02:38 PM |
