#31
Re: No OLED channel info on Mix after 3.7
What's a WS? work surface?
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12 |
#32
But that's what I'm saying...don't have EUCON auto start and see if that improves...it would help us to track it down.
#33
Hi Eddie,
Yes, if I remove Eucon from my startup items and start it up manually it works as expected and the Oled comes on straight away. Hope that helps.
#34
Great, that does help a lot !
#35
Also having removed and re-instated Eucon from my startup programs seems on first testing to have solved the issue.
I'll test further when I start up tomorrow, but maybe it is now fixed?
#36
Did the same - it worked several times now, so I think I have a workaround :) Would be cool if it can be fixed...
#37
We changed the way EuControl (and S6) startup and made it simpler. Maybe something got left behind from the previous versions that is causing the issue. Can I clarify, is EuControl still set to autostart and working OK now ?
#38
No - I removed it from autostart and start it manually, after it has started I switch on my Artist Mix Unit, Dock and Control are online from the beginning...
Need to test if it works when EuControl is in autostart and only Artist Mix is switched on later... |
#39
Hi Eddie, Roland.
I've auto started several times now after removing and replacing Eucon in Startup Items and everything is working as it should, that was the fix. Roland if you add Eucon to your startup items again, now you've booted without it, it will work. Or anyway it did for me. Fingers crossed. Thanks for the help tracking it down Eddie.
#40
@cheesehead: that worked! I tested it several times - it works now even if EuControl is in Startup Items... Thx! LG Roland |
no TRIM MODE info on oled displays? | cebolao | Avid S1, S3, Dock and Control App | 15 | 09-22-2017 07:59 PM |
Artist Mix Oled not working in one channel | Giba | Artist Series | 1 | 07-12-2017 06:52 PM |
OLED info time out ? | priorytools | Avid S4/S6 | 3 | 11-21-2015 09:48 PM |
Midi Channel Info | Sparky1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-15-2011 03:39 PM |
mc mix second channel 's OLED missing ! | klyg | Artist Series | 2 | 10-10-2011 10:14 AM |
