Old 10-17-2017, 09:09 AM
quincy_j_clomo quincy_j_clomo is offline
Default TCE Trim tool help - handles?
Hey all,
So I've found through much trial and error that elastic audio simply will not work for a multi-mic'ed guitar amp- regardless of EA plugin settings, number and location of event markers/warp markers, even when the tracks are in an edit group, the warping is always applied individually to each track, and phase gets audibly wild. NBD- I've also found that turning off EA and using the good old fashioned TCE trim tool works like a dream, just with a little bit of extra editing (split each note or phrase that must be warped into its own clip, TCE trim works equally on all tracks in the edit group, no phasing.) The only problem I've encountered with this is that sometimes you get a pop when two clips match up, and because the TCE trim tool only renders the exact boundaries of the clip you can't crossfade.
So is there a way to make the TCE-rendered clip have handles, or should I just try to build a little bit of a handle into the clips when I split them?
Old 11-12-2017, 10:54 PM
tomasblack tomasblack is offline
Default Re: TCE Trim tool help - handles?
Wow, thanks a lot. I was looking for solve of problem EA plugin!=)
Trim Tool Omar08 Pro Tools 10 4 09-08-2014 04:32 AM
Problems with Grabber Tool & Trim Tool S133 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-05-2008 10:19 PM
trim tool on 7.4.2 ? dendee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-18-2008 09:40 PM
Need help with use of Trim Tool Ross H 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-14-2008 10:07 AM
trim tool TravisDRS Pro Tools TDM Systems (Mac) 2 12-16-1999 02:08 PM
