OS X 10.4.5 has been released
Here are the details as reported at Macfixit.com:
"Mac OS X 10.4.5 includes the following enhancements: Internet, iDisk, and networking * Safari no longer quits unexpectedly when deleting AOL mail messages via AOL webmail. * Apple's IPSec VPN client now works with Cisco servers whether or not NAT is used. * Addresses an issue in which you could not sync with an iDisk larger than 4 GB. * Files copied across a network via Portable Home Directories are now copied as temporary files until the transfer is complete, in case the network connection is interrupted before the transfer finished. * Addresses an issue in which some Epson printers could not successfully print via AirPort Extreme. Other * Allows the rotating cube effect to appear as expected on both a primary and a mirrored display, when switching users via Fast User switching. * Addresses an issue for Mac OS X 10.4.4 in which background columns of text within the RSS Visualizer screen saver are sometimes superimposed over one another. * Dragging a widget out of the widget bar while the desktop picture is changing (automatically, for example) no longer stops the animation on an Intel-based Mac. * On an Intel-based Mac, Telestream Flip4Mac now installs correctly. * Prevents the Setup Assistant from unexpectedly quitting if Kotoeri is selected as the keyboard type following an English language installation of Mac OS X. * Allows applications that run using Rosetta on an Intel-based Mac to successfully open files that are located via an Open window's "search" field. * Addresses an issue in which Rosetta-translated applications running on Intel-based Macs would not correctly receive Keychain notifications. * Console no longer reports a series of "Quartz Composer QuickTime Component" messages for iMovie '06 when applying a Ken Burns clip or image. * Addresses an issue for iMovie HD and Mac OS X 10.4.4 in which iMovie could unexpectedly quit when switching themes. * Eliminates some potential video redraw issues when using Front Row on Intel-based Macs. * Updated the rules for time zones and Daylight Savings Time to conform to changes in the law for the United States, Australia, and other locations, for 2006 and later. * Addresses a potential issue that could cause the system process "configd" to unexpectedly stall. * Addresses an issue when viewing streaming media behind a firewall on Intel Macs. The new release is a 6.4 MB download in delta (10.4.4 to 10.4.5), standard form." It doesn't look like any of the CoreAudio stuff got messed with, but just the same, I'm staying at 10.4.3 with my system. YMMV of course. Josh |
Re: OS X 10.4.5 has been released
Chris Lambrechts Applications Specialist- Live Sound |
ahhhh come on take a risk for once in your life
clone your drive it is turns out to be whack clone it back. your heard it here first LOL
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
This alone should should pressure people to adopt iLok or other dongle technologies. There is no reason to restrict a user to a single machine -- software auths should be portable, on physical keys, such as dongles.
--Jeremy |
jimmy 15" Macbook Pro R 2.6 i7 Quad/16GB RAM/OS X 10.10.5 27" iMac 2.8 i7 Quad/16GB RAM/OS X 10.10.5 Studio One 3/Reason 8/Live 9/Logic Pro 9/Main Stage 3 |
Especially IK Multimedia. 3 auths to start with, if you use those you can request 3 more, then what? Re-buy a plug-in that you already purchased once, just for a couple of more auths! Anyone have any idea if IK will implement a dongle based authorization for Amplitube 2?
Ron
ron [k] Musician/Programmer/Engineer/Remixer System: PT HD v8.0.1cs2/PT 9 HD3 Accel, 96 I/O, 96i I/O, Control |24, Midi I/O, Sync I/O ___________________________ http://myspace.com/ronk http://ron-k.net/studio.html http://facebook.com/ron.k.music |
Then again though, how many "dongles" and "USB keys" can we have hanging around and dangling off our hubs cluttering up stuff.
Personally I like neither. I feel a new invention needs to happen that allows them to force the security they need, BUT NOT clutter up our lives at that expense. I mean if you add up your iLok, then if you also have Logic, your Logic Dongle, then if you want these other plugs you are talking about with their damn dongles, its like MAN,,,, where will it stop ?? Soon we will need 8 hubs with 8 usb expansions on each one just to turn on a recording session !! -- LOL -- I'm cool off that. I don't mind 1 master USB key for EVERY authorization I need in the WORLD. Like if it were iLok, then ALL companies offering dongle keys would have to move their licenses to iLok for us, I mean like Logic types included !! and ditch their stupid dongle - or whatever. Just make it so iLok held EVERYTHING we need. Some sort of a "License STANDARD"... after a while it will just be "the way it is". And all companies will know to do it or not make a product !! ha ha. Maybe you could put your drivers "license" and marriage "license" on it too !!! J/K lol -- I mean it sounds like a monopoly, BUT it is the ONE that sounds good, and would be to our benifit. MAYBE ??? What do you all think ? SO NOW, back on topic here,, has anyone went for 10.4.5 yet ?? Any problems with it and Pro Tools 7 HD ?? Come one, I know there are some gutsy people out there that did it. WHATS THE VERDICT ??
ROULETTE RECORDS™ (415)334-8742 office (267)219-4490 fax www.rouletterecords.com [email protected] Any fool can complicate things; It takes a genius to simplify them __________________ |
USB3 cranium port.
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . |
(Then there's naturally the issue about losing the key, but there's nothing iLok can do about it. Thank God we have insurance companies...)
Mac Os 10.6.3 just released | Chris7514 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-01-2010 08:03 AM |
It's here! 7.4.2 (not pr) released! | Slim Shady | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 24 | 06-23-2008 11:07 AM |
7.3 HD is released! | Produce_Dept | Pro Tools TDM Systems (Mac) | 84 | 12-07-2006 06:43 PM |
When is 6.4 LE for the UK to be released? | shutupandshave | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 06-20-2004 03:34 PM |
PT 6.2.3 Released ? | Dutchmuzik | Pro Tools TDM Systems (Mac) | 2 | 02-05-2004 07:06 AM |
