Old 04-25-2005, 10:01 AM
heartparts heartparts is offline
Default Center Panned Tracks Sound Dull. Any ideas?
For some reason, any track on any session that i listen to sounds really dull when it's center panned. When i pan to the left or right it clears up and sounds fine. This only happens when i listen through my monitors, when i listen to the track with headphones, it sounds fine center panned. What could be causing this.
I'm using a dual 2.0 G5, 1 Gig of Ram, and an Mbox running PTLE 6.4
thanks for any help.
http://www.mrfusion.net
Old 04-25-2005, 10:17 AM
Sevenlights Sevenlights is offline
Default Re: Center Panned Tracks Sound Dull. Any ideas?
The only thing I could think of is that your speakers could be out of phase, but that would sound like a loss of bottom end and an unaturally wide stereo field.
Scott Cooke.
Mountain View Records
Old 04-25-2005, 01:15 PM
but would that explain why it sounds fine when it's panned at about >25 on either side?
Old 04-25-2005, 01:35 PM
ggunn ggunn is offline
Yes, it would.
Gordon in Austin
Mac G4 Digital Audio 466MHz
MacOS 9.2, 1.25GB RAM, 110GB HD
digi 001, PT LE 5.3
Old 04-27-2005, 11:18 AM
Bluemoon Bluemoon is offline
Like you say, unlikely to be phase, would sound harsh and empty, not dull. What monitors are they, and are they active or passive, if so what amp? Don't forget that when you pan a signal in/out the relative db per channel increases up to +6db* therefore whichever direction you've panned will be driven harder. One reason why kick/bass always centre panned, so transient energy evenly spread and you don't blow your drivers.
*Depending on your mixer/monitor set up.
Is this the blues I'm singing?
G5 2.5dual, 4Gb Ram 2x250gb HDs. Using PTLE 6.9 under OS10.3.8.
Old 04-27-2005, 11:40 PM
JFreak's Avatar
JFreak JFreak is offline
it's a phasing issue.
first thing to do is to double-check that you have wired your monitor speakers correctly. if one of them is in wrong phase, that is very easy to locate and fix...
on the other hand, if wiring is correct, then you have a serious issue with speaker placement in your room, or the room itself. that is something you don't fix with eq. if that's the case, you need to first move your speakers into better placement, maybe different angling will help, and probably will also have to treat your listening room acoustically. there are no shortcuts and if you don't know how to do it, there are professionals who do just that very well.
Janne
A Dull sound in Protools SE for VO's kahico Pro Tools SE and Essential (Mac) 2 01-24-2013 12:41 PM
Panned tracks bounce to iTunes are no longer panned Patamuus Pro Tools 10 1 04-24-2012 11:30 AM
multiple guitar tracks panned ?? CrAkD Tips & Tricks 4 05-19-2005 07:11 AM
Consolidating Panned Tracks - Finalized In Stereo? ansanity 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-04-2005 08:12 PM
Centre Panned - now the sound level is dropped Da Gatekeepa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-26-2002 05:38 PM
