Old 02-28-2019, 03:35 AM
Ravenswood Ravenswood is offline
Default PT won't record with 2018.12 and Mojave
OK, so had to buy a new MacMini as due to wonderful Apple my MacBook Pro isn't up-gradable (RAM)!! a
Anyway just bought a new UAD Apollo x8P and when I arm and record there's no signal shown (not input monitoring as I have disabled it), then when I press play no signal is recorded.
If I create an Instrument track and put together a drum track in say EZDrummer, this is played through the UAD with no problems.
To save confusion, yes I'm recording on an analogue track - not instrument track, my I/O is correctly setup (I deleted the paths and updated from the Apollo) and have followed all instructions for setup. Plus I get sound and signal through the UAD control panel no problem.
I have a feeling it's a compatibility issue, so hopefully 2019 will be released soon.
Kind of frustrating as I want to play with my new UAD :) :)
Anyone else experience the same issues? Any suggestions?
Cheers people :)
Old 02-28-2019, 03:45 AM
the.engineer the.engineer is offline
Default Re: PT won't record with 2018.12 and Mojave
I'm not on Mojave but it sounds like you haven't enabled Pro Tools to 'use' the 'microphone' facilities inside system preferences. Apparantely you have to allow Pro Tools to access any audio hardware.
May be in privacy settings. Have you searched the other threads on here? That's where I read it.
Good luck.
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Mini 8,1 (2018) | 3.2 GHz 6-Core Intel i7 | 64GB Ram | Apple 27" LED Cinema | 2TB System Drive | LaCie Rugged USB-C 2TB SSD NVMe Audio Drive | UAD-2 Quad Satellite (Firewire)
macOS Catalina 10.15.7 | Pro Tools Ultimate 2021.7 | Avid HDX TB3 Chassis | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
Old 02-28-2019, 03:53 AM
HI James
Yes did that already, oddly, Avid gave me a trial license to try with my MacBook Pro which I had already up-graded to Mojave (to add a larger SDD) and it worked fine. Only seems to be an issue with my new MacMini
Cheers for the tip tough :)
Old 02-28-2019, 04:15 AM
Damn! Sorry, I have no other suggestions.
James Welch
Old 02-28-2019, 04:20 AM
Drew Mazurek's Avatar
PT, UAD, and Mac mini all good here.
Have you done all of this?
https://help.uaudio.com/hc/en-us/art...atibility-Info
www.drewmazurek.com
Old 02-28-2019, 05:59 AM
Thanks James and Drew
Yes, feels like I'm doing something silly or missed something basic. I did follow the instructions and gave permission etc but I'll check again - always happy to take advice and look at something I've missed :)
Kind of missing my HD rig, but can't justify HDX these days, but loving the UAD stuff :)
I'll let you know how I get on later.
Cheers
Paul
ProTools 2018.4 Ultimate and macOS Mojave BillDog793 Pro Tools 2018 121 03-07-2019 04:37 AM
New MacMini(i7), Mojave, PT 2018.12U, HD-Native littlesicily macOS 12 12-26-2018 06:03 PM
PT 2018.7 on MacOS 10.14 Mojave works for me veinticinco Pro Tools 2018 38 12-09-2018 07:35 AM
2018.10 works on MBP i9 with Vega 20 and Mojave DarkandKurious Pro Tools 2018 3 11-27-2018 12:23 PM
Pro Tools 2018 on Mojave does not register any incoming audio [email protected] macOS 3 10-29-2018 04:32 PM
