PTMP 8 << lower hardware buffer settings.. hooray!
to be verified still, but
from the whats new in v8 pdf: previously 128 was the lowest setting New H/W Buffer Size settings Pro Tools M-Powered for up to 48kHz sessions down to 64 up to 2048 for 96kHz Sessions: down to 128
17" MBP i7, 4GB RAM, Profire 2626, PT-MP 8 |
Re: PTMP 8 << lower hardware buffer settings.. hooray!
If this is true, then that is great news! Can one of you lucky guys that already has PTs confirm?
J |
Not true
With what interface are you using with Version 8 M-Powered, that this is not true? |
Profire Lightbridge
It *still* only goes down to 128 samples in M-Powered 8??? |
yes
That just makes so much sense.
I wonder which M-Audio interfaces get the 64 sample buffer. |
I can confirm there is NO 64 buffer setting with the Project Mix.
WTF? |
This will be a big disappointment after seeing the manual that clearly shows M-Powered buffers from 64-2048. Maybe it will be addressed in a CS release?
Hardware buffer settings. | L-Dogg | Eleven Rack | 5 | 02-17-2013 12:25 PM |
Can't Get To A Lower Buffer Settings | reycantong | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-09-2009 07:22 AM |
Hardware buffer size settings? | Eddie D | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-03-2005 01:48 PM |
why can't I use lower HW buffer settings? | m nightingale | Digidesign Hardware & Software | 3 | 09-25-2003 10:26 AM |
Aliasing? at lower buffer settings | Chris Cavell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 08-12-2003 07:45 AM |
