In your face stereo lead vocal....
I'm getting ready to mix a song in which I want to have the common big contrast between the verse and the chorus. The verse vocal is sort of dry, and I want to make the chorus very wide and phatt. I typically stack it with two passes, but I want to try something different due to the nature of the vocal. Any cool ideas that won't create phase problems?
Thanks! [img]images/icons/smile.gif[/img]
Christian Music Productions For the New Millennium |
Re: In your face stereo lead vocal....
You can do this a bunch of different ways. Use delays is the simplest. Do a short and long delay mono or use a stereo delay and take your short left and long right. If you have the ability you should pitch shift each one too. Increase the effects in the chorus. Good luck! Hope this helps.
If it's not too late, or in the future, try miking the singer using an M-S configuration.
You can easily go mono for the verses and get as much width as you'd like on chorus, even widen the vocal image progressively over a chorus. No phase problems at all, and guaranteed mono compatability. D |
I love "in your face" vocals, and I really don't think that stereo vocals is the way to go. Blending the right amount of different vocal takes right in the middle is what is going to give you that in your face sound.
Stereo on vocals can be interesting, but will never sound in your face. However, once you have your fat-in-your-face-mono track of vocals, you can always add some stereo element to it: reverb (pretty obvious), chorus, flanger, phaser, setreo-izer, or even other takes with effects (like disto...). But I would start with a big fat center track that brings the punch. |
Sometimes, if I am working on a TDM system I will copy the vocal track in the chorus. I will then run the copied vocal through Amp Farm and distort it, layering it under the main vocal.
On a 001 you can get the same effect by A: running the vocal into a POD if you have one and tracking the distoreted vocal. Or B: you can copy the track and run the copy through something like Sans Amp. This works for a fat rock vocal. [img]images/icons/smile.gif[/img]
recording engineer=audio photographer |
Keep them dry, the more effects used incorrectly will push them back, I dont care what they say, the dry vocal is always more in your face.
A Gentleman is one who can play the bagpipes, yet chooses not to. |
[img]images/icons/cool.gif[/img]
DesertDude 1.25 Alu/1.5 ram/10.3.4 PTLE 6.4-002R-Live-Reason |
verse-mono
chorus-stereo |
While I agree that dry is in your face. You can use delays so they fatten up the lead vocal. Some of you think that this means a vocal with delays bouncing across the track especially if you have two going at the same time (long and short). You couldn't be more wrong. These should so low you can't hear it in the track. Try a 16th and 32nd note. If you want delay for increasing effect try an 8th note where you can hear it.
Use of slight delays will make the voice fatter. Using less reverb makes it "dryer". |
Hey I did a mix for my buds, they wanted if your face vocals. There's a 40sec. sample of it here or here too! ,go to the audio page, let it load. They're Hate Wont Stop Hate. I used a mixture of Waves Renn Comp, McDsp's Compressor Bank3,and a pinch of verb. They were happy!
METAL LABS |
Processing the modern lead vocal | scrnplyr | Tips & Tricks | 35 | 09-26-2013 02:40 AM |
Compression on lead vocal (aux track)? | Segosha777 | Tips & Tricks | 12 | 01-02-2013 08:32 AM |
Lead Vocal Plug In | tomhartman | Pro Tools TDM Systems (Mac) | 27 | 07-23-2003 06:13 AM |
Lead vocal question | richie rich | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-31-2003 10:54 AM |
any way to get lead vocal softer during mastering? | village1 | Tips & Tricks | 5 | 03-08-2001 06:03 AM |
