Old 02-01-2020, 09:25 AM
kw88keys kw88keys is offline
Default 5-6 second delay when initiating record - RESOLVED
RESOLVED! The problem was drive A in the BIOS setting. Drive A was disabled but it showed a configuration for a drive. I removed that configuration to show no drive and now the troublesome delay on both record and playback-after-record is eliminated and the functions are working normally. Thanks to the member "The Weed" who suggested the A Drive could be the problem.
_________________________________________
[original post]
I have a problem with a 5-6 second delay when I press record.
I had been running PT 2018.4 on Windows 7 Pro with no problems.
A few days ago I upgraded to Windows 10 Pro and updated to PT 2019.12.
Now whenever I initiate [record] on the transport, there is this 5-6 second delay. There is no delay if I initiate [play]
Pre count is off. I also tested by re-installing 2018.4 but the problem remained. I have done the optimizations for Window 10. I also removed all third party plug ins and VIs but the delay remained'
Has any one else experienced this?
I was going to limit the record time but I see that option is no longer available in the preferences section.
5-6 second delay when initiating record kw88keys Windows 19 02-01-2020 04:01 AM
delay when initiating record kw88keys Pro Tools 2019 0 01-25-2020 07:31 AM
[RESOLVED] 10.3.6 Transfuser Record Problem? DFT Virtual Instruments 1 07-03-2013 10:41 PM
press record.... delay... delay...now it records phanatik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-20-2007 03:20 PM
