Go Back   Avid Pro Audio Community > Other Products > Pro Tools Express on Mac OS X
Old 06-08-2014, 08:41 AM
neioos neioos is offline
Default Cannot hear playback in Pro Tools Express?
Hello! I'm new to the forums and semi-new to using Pro Tools (however I have had experience with other software like Logic). I have Googled and searched for an answer to this problem, but so far I have had no luck.
I have the Mbox Mini and Pro Tools Express installed and working. Under the Playback Engine they only allow me to use the Mbox, which is fine because Pro Tools will only allow playback through the Mbox. When I record, there are levels and I can hear myself in my headphones, but when I go back to hear the recording, there is no sound. I have Track Record Enable turned OFF, so I know that's not the issue. I also have tried experimenting with the gain, mix, and master knobs. I'm fairly certain this is a software issue since I am able to hear myself in my headphones and am able to record successfully.
I have all of my I/O's set to default. Are there I/O settings that I am unaware of? I have tried changing some of the output and input settings to no avail. I went into my computer's preferences and set the audio output to Avid Mbox.
There is probably a simple fix to this problem that I have overlooked, so I apologize if this is a question that has been answered before. I feel as if I have exhausted all of my options. Any help would be appreciated. Thank you!
Mac OS X 10.8.5
Mbox Mini
Pro Tools Express
Old 06-08-2014, 09:06 AM
Default Re: Cannot hear playback in Pro Tools Express?
Nevermind! Got the playback up and running. Seems as if I simply didn't have the mix up high enough to hear the playback through my headphones. What a silly mistake! Thanks for the support of these forums anyway!
Mac OS X 10.8.5
Mbox Mini
Pro Tools Express
Old 06-09-2014, 11:44 AM
proudmom's Avatar
proudmom proudmom is offline
Im having the same problem i cant hear my audio i recored a song and couldnt hear it..
Im using pro tool express and M-Trackplus
Last edited by proudmom; 06-09-2014 at 11:49 AM. Reason: forgot to put what i have
Old 06-10-2014, 09:36 AM
JoelG's Avatar
JoelG JoelG is online now
Try going through this article at InMusic:http://www.noterepeat.com/articles/h...ai-pro-edition
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
No playback sound in Pro Tools Express ramadei Pro Tools Express on Mac OS X 3 10-31-2013 01:51 AM
I cant hear playback??? soulsharborax 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-03-2009 12:31 PM
Can't hear playback Crypticc62 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-14-2007 09:36 AM
How to hear yourself during playback.... TBF Entertainment Pro Tools M-Powered (Win) 5 07-31-2006 10:27 AM
I cannot hear playback nick hunter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-19-2005 05:32 PM
